How much torque for shock mount bolts??
#1436428
05/14/13 09:28 PM
05/14/13 09:28 PM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
1971 dodge clallenger. Instructions with shock say to torque to manufacturer's specs.
Can anyone recomend some numbers, front and rear?
thanks
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
Re: How much torque for shock mount bolts??
[Re: fireeng]
#1436429
05/15/13 11:12 AM
05/15/13 11:12 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
thanks
You can't find it in your factory service manual ???
Top or bottom ?
Do people actually torque shock bolts ?????
[Re: fireeng]
#1436430
05/15/13 12:15 PM
05/15/13 12:15 PM
Until they're tight.
[Re: mopowers]
#1436435
05/15/13 01:32 PM
05/15/13 01:32 PM
Challenger 1
Cincinnati, Ohio
For the front tops, I've always just tightened them until the rubber squishes to the same or close to the same OD as the washer. For some reason 35 ft/lbs stick out for the bottom bolt. FSM probably has a spec.
Show us...
[Re: Challenger 1]
#1436436
05/15/13 01:40 PM
05/15/13 01:40 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Show us...
Out of a '67 Plymouth factory service manual..
[Re: OzHemi]
#1436437
05/15/13 01:43 PM
05/15/13 01:43 PM
Challenger 1
Cincinnati, Ohio
Show us...
I stand corrected, I was wrong.
Is there torque specs for the rear? because that's what I thought we were talking about.
[Re: Challenger 1]
#1436441
05/15/13 02:00 PM
05/15/13 02:00 PM
OzHemi
Garden Grove, CA
I bet there is no torque spec in the FSM.
By the way, what was the bet for?
[Re: OzHemi]
#1436442
05/15/13 02:34 PM
05/15/13 02:34 PM
Challenger 1
Cincinnati, Ohio
Now your pushing your luck... We didn't shake so it don't count!
I'll bet I'll take a good ribbing for it for a while.
[Re: Challenger 1]
#1436443
05/15/13 09:36 PM
05/15/13 09:36 PM
fireeng
near New Haven, CT
Thanks for the help. I was liking for all the bolts as I replaced all 4 shocks. I don't have a FSM. Gotta get one of those.
