Break In - Restart Questions- Update
#1435813
05/13/13 02:19 PM
05/13/13 02:19 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
OK, here it goes. Last year I swapped engines in my 69 Road Runner. The old mill was 12.5:1 and I was getting a little sick of mixing race gas. I had another machined short block sitting on the engine stand and decided to add some closed chamber heads and a new cam and drop it in. My new compression ratio should be about 9.5 if I calcualted it right. I did not cc the heads for more accurate number, but that is ballpark. Here is the issue. I got everything on the car and started it up with Rotella break in oil to break in the cam. The car was running about 6 or 7 minutes when one of the heater hoses blew apart. Hot glycol shot everywhere including on me. Second degree burns on my side and back were the result, as well as spending the next day mopping up glycol out of light fixtures, windows, floor, etc. I was so pissed I disconencted the battery, covered the car up and put it away for the winter (this was just before the nationals last year).
So here it is spring, and I think I am over my anger towards the car now. I fixed the hose and checked the oil. The oil still looks brand new (no glycol in it), but its still the break in oil. I noticed the rear header bolt is leaking coolant as well as the thermostat housing. I will fix those this weekend. My plan was to start it back up and run for another 10 minutes at 2500 rpm to make sure cam was broken in properly. Change oil and finish sorting out other tune up issues with carb. I never had a chance to set idle misture (just 2.5 turns out now) or any other settings.
Sound like a plan? I am so paranoid about wiping a cam lobe with all the horror stories I have heard. Anything else I should look for.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: Break In - Restart Questions
[Re: MoparforLife]
#1435818
05/14/13 10:30 AM
05/14/13 10:30 AM
Posts: 1,880 Out in Left Field, NY
bobs66440
Prime the oil pump and run it...
I agree fully.
I'm not sure what they mean by "run it", but if it only has 6-7 minutes on it, I would continue the break-in process. Another 20 minutes at 2000-2300rpm.
[Re: bobs66440]
#1435819
05/14/13 12:40 PM
05/14/13 12:40 PM
dogdays
I am the one who usually says "run it". But, I don't think so in this case. While it is possible that no harm ewill result, I would strongly suggest pulling the intake manifold and rocker shafts, etc., and reapplying break-in lube to the cam lobes, at least the bottom of the lifters. You have too much at stake not to take this preventive measure. R.
[Re: dogdays]
#1435821
05/14/13 01:18 PM
05/14/13 01:18 PM
bobs66440
Yes, I didn't think of that. It wouldn't hurt for sure. Wiping a lobe now would really suck...
Re: Break In - Restart Questions- Update
[Re: RoadRunner]
#1435823
07/06/13 10:18 PM
07/06/13 10:18 PM
RoadRunner
Well, pulled the intake since I had the carbs off (see my 6bbl questions). Two lifters are wiped. I don't get it, I did everything correctly, at least to the Comp Cams documentation and recommendations from here. The springs matched the cam, I used the break in oil, plenty of break in lube on all surfaces. I am so frustrated and heartbroken as its summer and I still don't have a car to drive. I never had issues with flat tappet cams until two years ago. I thought taking some time off over the winter would help get me back in the mood, but seeing this happen is just taking the wind out of the sails again. Not sure what I am going to do next. Spoke with the wife, and selling the car is on the table as an option now, and buying something new (new Challenger, Camaro, or Mustang, or maybe Subaru BRZ or C6 Vette).
[Re: RoadRunner]
#1435824
07/06/13 10:24 PM
07/06/13 10:24 PM
Posts: 343 S.E.Mich
drew72
S.E.Mich
Do you have double springs and if so did you remove the inner spring for the break in ?
[Re: kenworth_goose]
#1435826
07/06/13 11:38 PM
07/06/13 11:38 PM
RoadRunner
OK, here is what I put into the car. I used a Comp Cams XE274H cam. Recommended springs were 911-16 (single spring) but they were out of stock. Machine shop used 981-16 as they were available (373 lb/in versus 370 lb/in). Since the machine shop was doing the valve job, they machined everything to fit. The springs are single springs with damper. The rockers are stock stamped rockers. I used three compete sets to come up with a set that was matched in length, distance to shaft, etc. Comp Cams lifters also used (I forgot the number, I'd have to go check the box).
[Re: RoadRunner]
#1435827
07/06/13 11:55 PM
07/06/13 11:55 PM
RapidRobert
I'd check the lifter fit by cleaning each lifter/lifter bore with brake kleen then lightly lube the lifters/bores with WD40 then lift each lifter off of it's lobe with your finger then let loose of it & each one should fall back onto it's respective lobe with a resounding thunk & if any of em dont then they are too tight & will not rotate properly & the cam/lifters will wipe. Other than that if the psi was not excessive & it started immediately then I'd say bad metallurgy in the comp cam and or lifter(s) which I've heard complaints regarding them. Sorry for your misfortune
[Re: Dodgem]
#1435830
07/07/13 03:30 PM
07/07/13 03:30 PM
RoadRunner
Double checked springs. Something is up. The box has 930-16 on label. But the springs in the car are not double springs. All I can see is the outer spring and a flat metal damper spring. So I am perplexed on what springs got installed. I hope there wasn't a switch at the machine shop that led to this.
[Re: Dodgem]
#1435832
07/07/13 05:33 PM
07/07/13 05:33 PM
RoadRunner
Definitely no inner spring. I crawled right up into the engine bay to get a close look. But, it sounds like not a good fit and possible root cause of issue.
Not sure of next step. Long weekend is over, and family vacation next week. I am not sure if I want to go with flat tappets again, or go roller now.
