904 leak #1435731
05/13/13 12:16 PM
05/13/13 12:16 PM
central PA
mopartial Offline OP
central PA
Have 75 A body 318/904. Leaking transmission fluid, appears to be coming from seal where kickdown linkage goes into top of tranny housing...
Anyone have a part number for this? How hard is it to replace that seal?
If it aint broke, dont break it.
Re: 904 leak [Re: mopartial] #1435732
05/13/13 12:59 PM
05/13/13 12:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Any parts store will have the seals and you will have to drop the valvebody to change them.
Re: 904 leak [Re: stumpy] #1435733
05/13/13 05:45 PM
05/13/13 05:45 PM
scratchnfotraction Offline
there are 2 seals in that area, the sift seal is a 1 1/4" seal the other is the throttle pressure lever shaft seal.
it is under the e-clip and washer below top TP lever.
best to replace both at this time IMHO.
I have the #s at home, a national seal or a mopar seal. I will post them later tonight for you.
Re: 904 leak [Re: scratchnfotraction] #1435734
05/13/13 06:52 PM
05/13/13 06:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
