AM Radio Station Lens (Repaint?) #1435610
05/13/13 02:13 AM
05/13/13 02:13 AM
California, USA
filmsurgeon Offline OP
California, USA
Can anyone help with advice on how to best "restore" the white numbering/lettering of the clear radio station lens? The clear plastic is in good, scratch-free condition. I basically need advice on the best way to repaint. Thanks.
Re: AM Radio Station Lens (Repaint?) [Re: filmsurgeon] #1435611
05/13/13 04:41 AM
05/13/13 04:41 AM
Alabama
BigMoneyLewis Offline
Alabama
The numbers are recessed into the lense on the E body AM, so a fine point white paint pen works well . Usually however the new paint is too white compared to the original .
To avoid all that hassle I usually just grab a better lense out of a parts radio .
Greg
gregward@mchsi.com phone 256-852-0955
Re: AM Radio Station Lens (Repaint?) [Re: BigMoneyLewis] #1435612
05/13/13 10:06 AM
05/13/13 10:06 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If the numbers are recessed, then you could use some Testors paint in them. Make sure you get good coverage...let it dry, and then wipe the excess off the face with mineral spirits.
Re: AM Radio Station Lens (Repaint?) [Re: burdar] #1435613
05/13/13 11:32 AM
05/13/13 11:32 AM
Miami Beach, FL
MannyE Offline
super gas
MannyE  Offline
super gas
Miami Beach, FL
That's pretty much what I used to do to paint model car dashboards. If the paint is "too white" you can add a little (and I mean a LITTLE) yellow, brown or green to tint the white a bit. I'm not sure exactly what shade the dial tends to lean towards, but Testors paints are so cheap it's easy to experimant. Also, once you have to color, you might want to thin it a bit so it will flow into all the nooks and crannies on the dial better.
Ni!
Re: AM Radio Station Lens (Repaint?) [Re: MannyE] #1435614
05/13/13 11:36 AM
05/13/13 11:36 AM
Miami Beach, FL
MannyE Offline
super gas
MannyE  Offline
super gas
Miami Beach, FL
In addition, go here:
http://www.antiqueradios.com/forums/viewforum.php?f=6&sid=a0bc571f6a41353a8bc95b81bdc336d4
And post pics of what you want to do. These guys can peobably help you get even better results.
Ni!
Re: AM Radio Station Lens (Repaint?) [Re: MannyE] #1435615
05/13/13 02:42 PM
05/13/13 02:42 PM
California, USA
California, USA
Thanks for the replies guys. Is it best or necessary to remove the old remaining paint first before repainting? If so, how best to do it? Thanks.
Re: AM Radio Station Lens (Repaint?) [Re: filmsurgeon] #1435616
05/13/13 03:31 PM
05/13/13 03:31 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I'd clean it out if you want it to be uniform, plastic polish or alcohol should remove it and when I do these I use a lacquer stick. Easiest to work with.
Re: AM Radio Station Lens (Repaint?) [Re: filmsurgeon] #1435617
05/13/13 09:27 PM
05/13/13 09:27 PM
Miami Beach, FL
MannyE Offline
super gas
MannyE  Offline
super gas
Miami Beach, FL
Yes indeed! If you can clean all the old paint off, then the new paint will be a uniform color...
Ni!
Re: AM Radio Station Lens (Repaint?) [Re: MannyE] #1435618
05/13/13 11:24 PM
05/13/13 11:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
To strip soak it in Castrol Super Clean..To apply paint in the groove use a syringe... To fill the syringe I pull the plunger out the back & pour the paint into the syringe... With practice you can get amazing results...
Re: AM Radio Station Lens (Repaint?) [Re: filmsurgeon] #1435619
05/14/13 06:58 PM
05/14/13 06:58 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
I'd send it to Greg Ward... he does GREAT WORK when it comes to radios.....JUST MY.....
