Re: Fuel gauge not working 1971 Dodge Demon
[Re: Randy514]
#1433947
05/10/13 12:54 PM
05/10/13 12:54 PM
Posts: 637 Maryland USA
beatgoeson
Maryland USA
I had one do that once. It worked fine moving it up and down. Mine had the tinest hole in the float. it would take on just enough gas when in the tank it would stay sunk. You might want to test the float.
[Re: Randy514]
#1433949
05/10/13 01:37 PM
05/10/13 01:37 PM
RapidRobert
Attach the ground strap with the clips that go on the sender nipple and the fuel line . The world doesn't need any more bald people
[Re: RapidRobert]
#1433950
05/10/13 02:44 PM
05/10/13 02:44 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Personally I throw the factory ground strap away.I attach a wire with a small hose clamp then use a sheet metal screw to the body.Never have any problems with them after that.The sender wont ground thru itself.You need the strap or run a wire to the sender nipple.Rocky
Chrysler Firepower
[Re: Randy514]
#1433952
05/10/13 03:08 PM
05/10/13 03:08 PM
therocks
Niles , Ohio
Run a ground from the battery to the outlet.If that dosent work it almost has to be the float.Put the sender assembley in a bucket of water and see if the float arm moves.It dosent take much for them to hang up or be heavy.Rocky
Chrysler Firepower
[Re: therocks]
#1433953
05/10/13 05:49 PM
05/10/13 05:49 PM
RapidRobert
If the sender is grounded then as said it has to be the sender assy itself (float/windings etc). I would fill the tank all the way up & if the gauge ain't pegged (Full) then it does not have a good ground because when the tank is full the rheostat windings are submerged & that is why the gauge is pegged with a full tank & it stays there for awhile before it starts to drop as the fuel level has to get below the windings so there's in effect no more dead short & it starts reading thru the actual resistance of the windings
[Re: Andrewh]
#1433957
05/11/13 12:52 AM
05/11/13 12:52 AM
Posts: 236 Southern CA
Colin Frolick
Southern CA
i had about that same problem, it was a bad float. i knew the wiring was good, gauge was good, dash volt regulator was good, ground was good, tested the sender with an ohm meter... still the gauge never got above ~1/8. $11 for a new float on eBag fixed it. Now i watch the gauge go down down down from full very quickly
[Re: Colin Frolick]
#1433958
05/13/13 08:27 PM
05/13/13 08:27 PM
Posts: 7,595 TX , NJ , FL
WINGCARS_6970
TX , NJ , FL
Ive unclipped the brass float from the sender and shook it.To check it
1969 Daytona 440 L9B410772
1970 Coronet 500 383 Presently owned
1970 Superbird 440 U 166242
1970 Superbird 440 U 174597
1970 Superbird 440-6 V 179697
1970 Coronet RT 440 U 224126
1968 Road Runner 426 J 134509
1970 Daytona Replica 318 G 178701
