Re: 1995 dodge dakota flywheel size/teeth
[Re: kams]
#1433374
05/09/13 08:28 AM
05/09/13 08:28 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Yup. most likely you need a 143 tooth wheel.
what wheel did you use? a 1995 360 should be a magnum engine, and the Magnums have their own special balance factor. And the only flywheels that come with the Magnum's balance are 143 tooth wheels, unless you buy one of the MP 130 tooth ones that do not have the windows for the crank position sensor, intended for a carb only motor.
is this engine running on a carb, or on the factory EFI?
**Photobucket sucks**
