converter to flex #1432356
05/08/13 05:15 PM
05/08/13 05:15 PM
L.I. N.Y. Hemi Street
HemiGreg Offline OP
HemiGreg  Offline OP
what size is the head of factory converter to flex plate bolts (4) thanks
how do you remove all these when engine is locked up
Re: converter to flex [Re: HemiGreg] #1432357
05/08/13 05:39 PM
05/08/13 05:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you cant turn it to pull the conv bolts pull the
conv out of the trans when you pull the engine or
the trans.. will make a mess with the fluid
EWDIT
It takes a 3/4 wrench for the bolts
Re: converter to flex [Re: HemiGreg] #1432358
05/08/13 10:55 PM
05/08/13 10:55 PM
It depends on which converter and which bolt size, 5/16 diameter(9/16 wrench or socket size I think) or 7/16 diameter bolts which may have either 11/16 or 3/4 bolt head sizes
Re: converter to flex [Re: Cab_Burge] #1432359
05/08/13 11:13 PM
05/08/13 11:13 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
if its a old Hemi its the big ones.
Section 8 Racing We are nuts about racing.
