Re: Rear gear
[Re: 69suprbee]
#1432076
05/08/13 12:29 AM
05/08/13 12:29 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
what size are your rear tires.
I am truckless..
Re: Rear gear
[Re: 69suprbee]
#1432078
05/08/13 06:50 AM
05/08/13 06:50 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
3.23s to 3.55s isnt really noticeable. 3.73s would be better but they are not available for all 3 cases IIRC. I like my 3.91s and would love to go to 4.30s but I have a OD 833 which helps a lot..
I am truckless..
Re: Rear gear
[Re: 69suprbee]
#1432080
05/08/13 05:25 PM
05/08/13 05:25 PM
RapidRobert
(1) 3.91 (2) swap in a 451 ![](/ubbthreads/images/graemlins/apimp.gif) . Exhaust/brackets etc all will change over
Re: Rear gear
[Re: forphorty]
#1432082
05/08/13 09:05 PM
05/08/13 09:05 PM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
If you are currently running a stock converter, a converter change will probably make more differance than a gear change. A 280 cammed 383 would probably like a 3500ish 9.5 or 10 inch.
![](/ubbthreads/images/graemlins/iagree.gif)
Kevin
Re: Rear gear
[Re: 69suprbee]
#1432084
05/08/13 10:43 PM
05/08/13 10:43 PM
Posts: 4,967 WI
Dcuda69
WI
Re: Rear gear
[Re: Dcuda69]
#1432085
05/09/13 08:48 AM
05/09/13 08:48 AM
Posts: 5,115 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
My 383 in my 70 Satellite is also a little lazy off the bottom. I think maybe just a bit too much cam in mine. I run 3.23's and have 275-60-17 rear tires. They measure right at 30". Last spring I put 3.91's in and ran them for a month or so. it helped it turn on sooner but it was exactly the same at initial start. I know it needs a converter, that would be the correct fix, but I am going to stay with the 1800 anyway. It runs pretty good from 2800 to 5500 or so.
...FAFO...
Re: Rear gear
[Re: skicker]
#1432086
05/09/13 02:44 PM
05/09/13 02:44 PM
Posts: 17 oklahoma
69suprbee
oklahoma
sounds familiar.the bee has a 2000 stall in it.i am getting ready to put headers on it and upgrade the carb to a 750 cfm along with the posi and the 3.73.i hope its a different car.not that its bad now,just want to be able to burn both tires until i let off the throttle!
Re: Rear gear
[Re: 69suprbee]
#1432087
05/09/13 06:50 PM
05/09/13 06:50 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
You may or may not burn both tires until you let off with a 2000 RPM 'verter. I'm running the Hughes Whiplash (0.518 lift, 229 degrees intake 242 degrees exhaust at .050) cam with 3.73 gears and 275/15/60 rear tires. It took some doing, but I finally got it tuned correctly and now can cook the tires from a standing start. Just standing on it, not doing a brake burnout first. That's with a 'verter that flashes to 2500 RPM. Not that I want to blow the tires off from a start, that doesn't get you to far to quick. If I bring up the R's a bit against the 'verter first it gets better traction. That way I'm not shocking the suspension and breaking the tires loose so bad. Just sayin'.
