Anyone use a Quick Fuel 1050cfm 4150? #1432027
05/07/13 10:38 PM
05/07/13 10:38 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Disclaimer: Bob has told me this car is begging for a 1050 Dominator....it has been noted..
I'm also looking at the AED 1000cfm 4150...any input on gains over a 850 Holley with either of these two carbs?...just keeping my options open since my air pan, linkage, throttle stop and intake are all set up for 4150....thanks
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: Eric] #1432028
05/07/13 10:44 PM
05/07/13 10:44 PM
tboomer Offline
tboomer  Offline
Why do you ask and not listen? Yes,Eric...You need more carb on that thing!! Go gettum!!
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: tboomer] #1432029
05/07/13 10:48 PM
05/07/13 10:48 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
I'm not disputing the wisdom Ted.. ...just curious to see if the bigger 4150 would be worth the time.. Truthfully the car is plenty fast enough for me...but some more mph Throttle Stop racing would be nice.
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: Eric] #1432030
05/07/13 10:49 PM
05/07/13 10:49 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Got one on my car and I love it When I put the dual plane on needed a 4150 so I sold the Dominator and got the Pro-Max/Quick fuel 4150 and it performed perfect out of the box.I have since read my plugs and bumped the jets 2 sizes and now it's even better.
If you want to make the 2 hour drive you can try it out My car won't be back together for a few weeks.
Gus
64 Plymouth Savoy
Dana 60
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: fourgearsavoy] #1432031
05/08/13 07:24 AM
05/08/13 07:24 AM
pa
572charger Offline
572charger  Offline
pa
come get my prosystems dominator test drive it eric
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: 572charger] #1432032
05/08/13 08:28 AM
05/08/13 08:28 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I have only 484 cubes on my Hemi, and I typically run a lot of carb on my combo, but when I called Patrick he recomended a Pro Series 1000 4150 instead of the SV1 on my combo. Its basically a dominator with a 4150 flange. It flows over 1000cfm and has the 50cc pumps, and Dominator metering blocks.
Works really well out of the box. I have the fastest ET to date with this over my efi and other carbs. Plugs look good too. If your trying to not buy an intake for a dominator, I would probably go with this or an SV1...The SV1 works on either style flange....And I was not sure if mine would be well into the +700hp range or just peak at 700hp, so I went with the 4150 for now. If I squeek out another 50hp somewheres, the SV1 makes better sense.
I could lend it to you for a couple of weeks, my Hemi is comming out again. I seem to have the worst luck....
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: Dragula] #1432033
05/08/13 09:53 AM
05/08/13 09:53 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Eric I would take Dragula up on that deal. I think your car would love a 2" adapter and a Dominator but as you said, you would have to buy other parts too so it makes sense to stay with a 4150.
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: ProSport] #1432034
05/08/13 11:33 AM
05/08/13 11:33 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have the intake for the 4500.
A new word has been established "Askhole"and defined as a person who constantly asks for advise but never listens.
Word around these parts is Eric is scared to let that big dog loose.
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: Dragula] #1432035
05/08/13 11:47 AM
05/08/13 11:47 AM
Renton Washington
Triple Threat Offline
Renton Washington
I'd take Dragula up on his offer as well.
FWIW I went from my tried and true 750HP to an AED 1000HP and picked up about .05 in the 1/4. This was on my 525hp pump gas 390" motor.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: B G Racing] #1432036
05/08/13 12:17 PM
05/08/13 12:17 PM
Surprised the filtered didn't catch that one...LOL
Eric,
How much hp are you running now?
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: Dragula] #1432037
05/08/13 12:32 PM
05/08/13 12:32 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Eric,
What the grumpy bear fails to realize is that the intake is not the only change I would need to make...some of which are sensitive...a word probably not in his vocabulary...
Approx 700-725 based on ET I would think Dragula..
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: Eric] #1432038
05/08/13 12:59 PM
05/08/13 12:59 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Eric,
Sensitive is that another word for,frugal or cheap,like Eric is sensitive to the cost. But seriously if you want to stay with a 4150 a 1000 cfm would certainly work,then you can throw some timing in the bad boy. If you want to try out the manifold you are certainly welcome to pick it up(you have to buy the gaskets)
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: B G Racing] #1432039
05/08/13 01:07 PM
05/08/13 01:07 PM
tboomer Offline
tboomer  Offline
Thanks alot,Bob!! I just spit coffee all over my keyboard!!
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: B G Racing] #1432040
05/08/13 01:19 PM
05/08/13 01:19 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Eric,
I am have a USED set laying around Eric.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: pittsburghracer] #1432041
05/08/13 07:05 PM
05/08/13 07:05 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Eric,
John the ones I'am selling him are used,he'd never spend $20 for a new set.
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: B G Racing] #1432042
05/08/13 10:23 PM
05/08/13 10:23 PM
tboomer Offline
tboomer  Offline
Eric...When I change my heads,I am getting new spark plugs. Just pm your address and I will send you the old ones...For Free!!
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: tboomer] #1432043
05/08/13 10:30 PM
05/08/13 10:30 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
The QF1050 is a nice carb. I have one on my 572ci pump gas build and it runs great and makes excellent power. On the dyno we compared the QF-1050 vs an 1150 dominator and the difference was 6hp on a 720+HP build.
Ron
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: firefighter3931] #1432044
05/09/13 01:02 AM
05/09/13 01:02 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I run one for 1 season prior switching to alcohol and the toilet. Really liked it but didn't like the price of fuel. Eric PM me if you are interested. QF 1050 annular 4150. Beep
Re: Anyone use a Quick Fuel 1050cfm 4150? [Re: Bigbeep] #1432045
05/16/13 04:32 AM
05/16/13 04:32 AM
Pittsburgh, PA
bobdog106 Offline
bobdog106  Offline
Pittsburgh, PA
I love my QF 1050. I ran Jim's Dominator back to back and it ran the same times. Needless to say I kept mine as it was nicer to drive on the street. Obviously with some tuning the Dominator would make more power, but I was content with QF.
