144-4201 stud kit----12 point nuts
Automotive Racing Products
Tel: (805) 33
9-2200
1863 Eastman Avenue Fax: (805) 650-0742
Ventura, Ca 93003
www.arp-bolts.comINSTALLATION METHOD FOR HEAD STUD KITS
200,000
PSI 1/2 inch
Diameter
1. To ensure proper thread engagement and accurate torque
readings, clean ALL threads in the block. Chase if
necessary with ARP Thread Chaser.
2. Clean and inspect all hardware prior to installation. Look
for obvious defects or shipping damages, plus proper fit,
length and dimension.
3. If the cylinder head studs protrude into a water jacket,
lubricate the block threads of the studs with ARP
THREAD SEALER.
4. Screw studs into the
block “HAND TIGHT ONLY”.
NOTE: LOCTITE MAY BE USED IF A PERMANENT
MOUNTING OF THE STUDS IS PREFERRED. THE
FASTENERS, HOWEVER, MUST BE TORQUE
D PRIOR TO THE LOCTITE SETTING UP.
5. Install the cylinder head(s) and check for binding or misalignment.
6. Lubricate the stud thread
s, nuts and washer
s with ARP ULTRA-TORQUE F
ASTENER ASSEMBLY LUBRICANT.
Then install the washers and the nuts on
to the studs and tighten them hand tight.
ARP recommends using the
ARP ULTRA-TORQUE FASTENER ASSEMBLY LUBRICANT th
at is provided with each kit as opposed to
motor oil. This is due to higher friction on the stud
s as well as inconsistencies in the clamping force of
the fasteners when motor oil or other low quality lubricants are used.
PRELOAD (TORQUE) RECOMMENDATIONS
7.
Following the manufacturers recommended torque sequence tighten the nuts
in three equal steps to
110
ft lbs
with ARP ULTRA-TORQUE FASTENER ASSEMBLY LUBRICANT.
Note:
ARP Ultra-Torque Fastener Assembly Lubr
icant has been specifically designed to reduce tension preload scatter and
eliminate the need to cycle high performance engine fasteners
before final installation. ARP Ultra-Torque far surpasses all
requirements offered by previous ARP lubr
icants in terms of fastener preload
repeatability and performance lubricating
properties. For more information on AR
P Ultra-Torque visit our website at
www.arp-bolts.comor call 1 800-826-3045.
