Lost & Found Engines & Transmissions #143135
10/29/08 11:14 AM
10/29/08 11:14 AM
Retired now in Tennessee
Chi_Town_Runner Offline OP
In an earlier post someone mentioned that a single list of vin #s for lost & found Engines & Trans would be helpful.
When I checked the L&F section of the board I found that going through 11 pages of info was somewhat laborous. So I have compiled a single sheet in an Excel spreadsheet format of all the vins of the L&F Engines and Trans with contact information. Realize that some of this information is dated and may be years old. But if your looking for a start on your search this may help. I tried to be as accurate as possible.
I will update this info weekly.
Hope this helps out somebody.
Please continue to use the Lost & Found section of Moparts web page for posting. I will update my sheet from that page.
Frank
(edit) If someone needs something corrected on this sheet PM me with the vin # and the corrected information.
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Lost & Found Engines & Transmissions [Re: Chi_Town_Runner] #143136
10/29/08 11:22 AM
10/29/08 11:22 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Great Job!
Re: Lost & Found Engines & Transmissions [Re: 68CoronetRT] #143137
10/29/08 11:22 AM
10/29/08 11:22 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
OMG that is awesome Frank!
Re: Lost & Found Engines & Transmissions [Re: Chi_Town_Runner] #143138
10/29/08 11:26 AM
10/29/08 11:26 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Awesome work. This is a much easier format to read. Moderators, can we get a "Sticky" please?
Re: Lost & Found Engines & Transmissions [Re: Dave Watt] #143139
10/29/08 11:44 AM
10/29/08 11:44 AM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
Well done! Much needed and user friendly.
Re: Lost & Found Engines & Transmissions [Re: ryangtogtx] #143140
10/29/08 01:14 PM
10/29/08 01:14 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Fantastic Job.
Very well done.
I will make sure to enter and engine and trans in L&F so they get on here.
Not to be greedy, but...Maybe Sheet 2 is Broadcast Sheets???
Re: Lost & Found Engines & Transmissions [Re: Chi_Town_Runner] #143141
10/29/08 01:23 PM
10/29/08 01:23 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Wow! I'm impressed! Nice work!
*As a side note, strange as it may be, the Hemi 4 speed trans VIN I posted does in fact have a "G" stamped where you inserted a ?
Re: Lost & Found Engines & Transmissions [Re: RP's R/T's] #143142
10/29/08 01:25 PM
10/29/08 01:25 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Nice work Frank.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Lost & Found Engines & Transmissions [Re: 69CoronetRT] #143143
10/29/08 02:11 PM
10/29/08 02:11 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
THANK YOU!!!
Re: Lost & Found Engines & Transmissions [Re: RP's R/T's] #143144
10/29/08 02:19 PM
10/29/08 02:19 PM
"Broadcast Sheets"!!!!! OUCH!!!!!
Well, lets see how this goes. I spent about 12-13 hours inputting the data on the engines and trans' so it would be easy to read and mainitain. I checked the broadcast sheet section and they are divided by body type (that helps me)but there are a lot more.
I did notice that at least 1 person (I didn't go through all the sheets) was looking for his broadcast sheet, engine and trans. Well when I checked the lost and found for engines and trans' his wasn't listed. Just a suggestion...folks should post engine and tran's wanted seperate from the boradcast sheets lost and found.
It may help in thier search.
Thanks for the suggestion.
Frank
Re: Lost & Found Engines & Transmissions [Re: Chi_Town_Runner] #143145
10/29/08 02:51 PM
10/29/08 02:51 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Frank - nice work and appreciated.
I've been a member here for quite some time and didn't know there was a L/F. Suggest getting the mods to make the L/F an element of the main index.
Re: Lost & Found Engines & Transmissions [Re: Chi_Town_Runner] #143146
10/29/08 04:09 PM
10/29/08 04:09 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Very Nice Worh Frank!
Re: Lost & Found Engines & Transmissions [Re: rrunner] #143147
10/29/08 05:35 PM
10/29/08 05:35 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
excellent! Great Job!
Re: Lost & Found Engines & Transmissions [Re: Finoke] #143148
10/29/08 05:40 PM
10/29/08 05:40 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Thanks for taking the time and going through all the effort required to do a much needed job.
Well done.
Re: Lost & Found Engines & Transmissions [Re: Snoopy] #143149
10/29/08 06:34 PM
10/29/08 06:34 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
Very nice work and helpfull.
One question.... How do I get my info in this list?
I am looking for my engine, trans and BS (LA based car so I am sure the BS is non Existent)
0E122968
If NO one minds I may look into uploading this file on my website for the masses to check out......
71 GTX 4sp Dana GY9 HD Road King
Re: Lost & Found Engines & Transmissions [Re: AZ-Nick] #143150
10/29/08 06:40 PM
10/29/08 06:40 PM
Snoopy Offline
Snoopy  Offline
Go to Engine and Trans Lost & Found and reply to any of the posts and list your wanted or found engine or transmission.
Re: Lost & Found Engines & Transmissions [Re: AZ-Nick] #143151
10/29/08 06:43 PM
10/29/08 06:43 PM
Nick,
Go to the "Main Index" then down to "Moparts Club and Registry". There you will find the L&F section.
If you enter your information there I will incorporate it into my spreadsheet. I will do this on a weekly basis for new information.
As far as loading it onto your web page the only problem may be that when a non Moparts member clicks onto the link that takes him to a personal page, I don't know if non-members can get in. But if you want to post it be my guest. I just hope it doesn't open a can of worms where the entire WWW will start flooding the site with info (good and bad).
I just completed this today so if you would't mind, can we wait for a little while (maybe 2 weeks) to see how this goes. I keep thinking of that commercial where we watch the internet hits hit 6,000,000 in about 15 minutes.
Frank
Re: Lost & Found Engines & Transmissions [Re: Chi_Town_Runner] #143152
10/29/08 06:45 PM
10/29/08 06:45 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
Nick,
Frank
understood
Re: Lost & Found Engines & Transmissions [Re: Snoopy] #143153
10/29/08 06:51 PM
10/29/08 06:51 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
thanks, its a done deal.....
Re: Lost & Found Engines & Transmissions [Re: AZ-Nick] #143154
10/29/08 10:23 PM
10/29/08 10:23 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Very generous of your time, and extremely considerate. Thank you. Added my info tonight.
