2010 Avenger 2.4L engine hesitation #1431254
05/06/13 12:24 PM
05/06/13 12:24 PM
Atlanta Indiana
Dave Watt Offline OP
Atlanta Indiana
My 2010 Avenger 2.4L engine has a hesitation that feels as if you shut the key off for a second, then it picks right back up. Mostly during part throttle acceleration such as taking off from a dead stop. Other times it's when accelerating to get around a slower car.
I was thinking of:
A: Throttle Position Sensor
B: Crank Sensor
C: Cam Sensor
Any ideas would be appreciated.
Re: 2010 Avenger 2.4L engine hesitation [Re: Dave Watt] #1431255
05/08/13 07:48 AM
05/08/13 07:48 AM
Atlanta Indiana
Atlanta Indiana
For the day shift crowd.
Re: 2010 Avenger 2.4L engine hesitation [Re: Dave Watt] #1431256
05/08/13 10:47 AM
05/08/13 10:47 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My 08 Sebring has done this twice in the last month.
Re: 2010 Avenger 2.4L engine hesitation [Re: burdar] #1431257
05/08/13 11:27 AM
05/08/13 11:27 AM
Atlanta Indiana
Atlanta Indiana
My '04 Sundance did this quite a bit once it hit 200,000 miles. Never did figure out what it was. My buddy drove the car until 240,000 before it went to the junkyard.
Re: 2010 Avenger 2.4L engine hesitation [Re: Dave Watt] #1431258
05/08/13 11:40 AM
05/08/13 11:40 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I was thinking of:
B: Crank Sensor
C: Cam Sensor
Under warranty? Bring it right to the dealer.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 2010 Avenger 2.4L engine hesitation [Re: VincentVega] #1431259
05/08/13 12:23 PM
05/08/13 12:23 PM
Atlanta Indiana
Atlanta Indiana
No, it has 85,000 miles on the 36,000 mile warranty.
At least if there was a fault code it would be much easier to diagnose.
Re: 2010 Avenger 2.4L engine hesitation [Re: Dave Watt] #1431260
05/08/13 12:34 PM
05/08/13 12:34 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
That's the basic warranty. The powertrain warranty should be 5 years, 100,000 miles.
Re: 2010 Avenger 2.4L engine hesitation [Re: VincentVega] #1431261
05/12/13 12:37 PM
05/12/13 12:37 PM
Atlanta Indiana
Atlanta Indiana
While trying to think what could be causing the hesitation issue, it was time to fill up with gas. I decided to run a tank of Premium just as an experiment. So far, the hesitation is 99% cured.
Spark plugs are next.
Re: 2010 Avenger 2.4L engine hesitation [Re: Dave Watt] #1431262
05/12/13 12:48 PM
05/12/13 12:48 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
There were some issues with the throttle bodies on the 2.4s that caused this problem. The problem was with the electric motor that operates the throttle not being able to move the sticking throttle blade, causing a hesistation sometimes. You may try cleaning the throttle body real good and see if this helps.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2010 Avenger 2.4L engine hesitation [Re: 71yelladustr] #1431263
05/12/13 02:06 PM
05/12/13 02:06 PM
Atlanta Indiana
Atlanta Indiana
Thanks, I'll try the throttle body cleaning too.
Re: 2010 Avenger 2.4L engine hesitation [Re: VincentVega] #1431264
05/12/13 02:12 PM
05/12/13 02:12 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I highly doubt the powertrain warranty will cover drivability issues. I second the throttle body cleaning
