Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: Troy] #14323
05/01/08 06:12 AM
05/01/08 06:12 AM
WILKES-BARRE PA
Joesixpack Offline
Joesixpack  Offline
WILKES-BARRE PA
ok like a 340-4bbl?
426 HEMI block code HELP [Re: M_code_Coop] #14324
07/07/08 08:56 PM
07/07/08 08:56 PM
clifton, nj
426gtm Offline
426gtm  Offline
clifton, nj
Have a 66 HEMI block and need help decoding. First of all I don't understand the coding so if we could start there and what the sequence means, that'll be a big help.. Here goes.. first digit N, second is either an M with the first leg missing on the left or a V with an extra leg to the right.
Anyway, here's how it looks...N, whatever letter, 42622390016.
Any help or education would be appreciated....Gary
Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: M_code_Coop] #14325
07/07/08 10:00 PM
07/07/08 10:00 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
Is the list supposted to be parts unique to the A-12 cars?
If it is the 2926233 horn 'beep beep' is not unique to A-12 cars, but standard to all 69 RR's.
Like wise the the 2808868/69 horns were not unique to the super bee but standard on all 69 Dodges and Plymouths, except the RR. .
Re: A12 Part Numbers [Re: M_code_Coop] #14326
08/15/08 06:57 PM
08/15/08 06:57 PM
Rod Stampimg # Is 2951906 and a 6pk rod has wider beam also thast 6029 575-6 is a lt&rt Pn, 60 numbers are all clip , nuts and bolts etc, als the last servive # i new of For a bbl rod was 2951908 as the were used in mid 70s motorhomes and poice cars, as for the Air cleaner base i never Could find A3 for thecorrect one were do i get my info from workin mant years in Dealer parts.Also dealer i worked at was a big dC dealer.there was a Insert in 69 pas car catatalog thatwas sent from chryler as my stay at the dealer were in found it was short and never had a chance to copy it.
