A12 Part Numbers/Current OTC available "NOS" parts #14303
02/13/05 09:56 AM
02/13/05 09:56 AM
Harleysville PA
M_code_Coop Offline OP
Harleysville PA
Listing A12 Part numbers in numeric order for reference. Here's something to start with-- Please correct
where necessary, and add to if able (not sure about fuel pump and a few others).
Still waiting for the PN for air cleaner base, steering pump, and hood(?)
J11Y spark plugs (Champion- gap.035)
4391 (list) 52 (PN) man center Holley carb
4392 (list) 53 (PN) auto center Holley carb
4393 (list) 50 (PN) both front Holley carb
4394 (list) 51 (PN) both rear Holley carb
6353 hurst shifter - (number found on reverse arm)
DR1114420 solenoid Delco Remy
1686107 radiator cap (dimple/16#)
1857780 torsion bar (right)
1857781 torsion bar (left)
2098300 voltage regulator
2444241 coil Chrysler-Essex (long)
2444242 coil Chrysler Prestolite (short)
2444442 starter relay (auto)
2444453 starter relay (man)
2444478 alternator pulley (single)
2530688 crossmember (man)
2532401 oil pan '402'
2536121 motor mount rubber insulators
2536132 right motor mount bracket
2539795 leaf spring (left)
2539965 leaf spring (right)
2642635 37 amp alternator
2642944 37 amp alternator with pulley
2658454 timing cover
2658888 exhaust manifold counterbalance
2780988 (PN) 2780987 (cast) water pump housing
2785434 fan shroud
2806070 fan torque clutch
2806216 fan belt
2806270 oil pump
2806898 (PN) 2806900 (cast) right exhaust manifold
2808068 horn 'low' note (bee)
2808069 horn 'high' note (bee)
2822461 horn relay
2843991 (PN) 2843992 (cast) left exhaust manifold
2860356 rear crossmember (oval gas fill opening more common than round on A12s)
2863216 fan (7 blade)
2863245 radiator hose outlet
2863257 radiator hose inlet
2863751 left motor mount bracket
2875711 alternator pulley (double)
2875981 IBS4014C distributor (man)
2875982 IBS4014D distributor (auto)
2881938 crossmember (auto)
2892093 auto trans
2892624 (PN) 2892626 (cast) bellhousing
2899052 valve cover (left)
2902966 right quarter panel scoop
2902967 left quarter panel scoop
2926233 horn 'beep beep' runner
2930781 fender turn signal indicators
2944169 H wheels
2946464 valve cover (right)
2949054 radiator 26 inch
2983116 wiper motor
2996560 driveshaft (runner)
2996581 driveshaft (bee)
3004107 carter fuel pump
3410609 man trans
3412046 Edelbrock intake manifold
3577389 wide lip orange air cleaner lid(w decals)
3577459 wide lip orange air cleaner lid(no decals)
4349216 Mopar Street Hemi Orange Paint for lids
6029575-6 Dana 60 4:10, with 11 inch backing plates
69 Six Pack Internals
2205568 crank sprocket
2532490 camshaft sprocket
2532492 timing chain
2536430 block casting number
2658457 vibration damper
2843906 cylinder head
3004535 pistons
3004718 rocker arm (rh)
3004719 rocker arm (lh)
3418475 intake valve
3418479 exhaust valve
3418491 valve springs
3420039 cam tappet
3420228 rings
3462038 camshaft
3462426 (PN) 1851535 (cast) connecting rods
3512036 six pack crankshaft
Click on link below, then click on attachment to view Current OTC MOPAR available "NOS" parts.
This is a very important list which includes all those suspect parts referred to as "NOS",
found on ebay etc etc.
Noticed a few of our favorite controversial parts here. LOL
Should save us all some money! Thanks to Tom Quad for compiling
Moparts post.
Link to Slideshow...turn the music up. http://albums.phanfare.com/isolated/F39VvCq5/1/1491997 ...So when does government's A12 welfare start?..
Re: A12 Part Numbers [Re: M_code_Coop] #14304
02/13/05 11:15 AM
02/13/05 11:15 AM
Harleysville PA
Harleysville PA
Guys,
if you email at uponrs@comcast.net (or PM) I will update the list with whatever number you
have (just got auto trans and H wheel numbers from AZ Dave).
As the list grows, if we want to discuss right or wrong numbers on it, we can do it in the thread.
Regards,
Coop
Re: A12 Part Numbers [Re: M_code_Coop] #14305
02/17/05 12:11 PM
02/17/05 12:11 PM
Harleysville PA
Harleysville PA
bump- check the current mopar OTC "NOS" parts listing added to the first post.
There are probably some subtle differeces between todays "NOS part" and an original-
but the parts list is very helpful none the less. Thanks again to Tom Quad
for compiling!
Re: A12 Part Numbers [Re: M_code_Coop] #14306
03/19/05 06:15 PM
03/19/05 06:15 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: A12 Part Numbers [Re: 6PakBee] #14307
03/20/05 10:09 AM
03/20/05 10:09 AM
Harleysville PA
Harleysville PA
Just added the 69 six pack internals list.
Just a follow up on a previous thread
'How to ID a 6-pack motor'. The question
of the rod having hemi connections via
its number came up. Checking rod data
carefully the 69 six pack rod PN is
3462426 but the cast is 1851535 (see attached chart).
That helps explain the confusion.
They sport a different part number, than
the rest of the stock rods (cast 1851535)
that are in thousands of 413s, 426s, and
440s from 64-74 (PN 2406770)-- due to
the magnaglo inspection.
1580992-rod chart.jpg.gif (774 downloads)
Re: A12 Part Numbers [Re: M_code_Coop] #14308
05/01/05 01:32 PM
05/01/05 01:32 PM
Harleysville PA
Harleysville PA
bump
Re: A12 Part Numbers [Re: M_code_Coop] #14309
05/01/05 01:47 PM
05/01/05 01:47 PM
The Last Frontier
Alaska_A12 Offline
Alaska_A12  Offline
The Last Frontier
bump
Is it possible to give this thread a sticky pin to keep it up top?
______________________________________________ http://regcars.homestead.com/car107.html
Re: A12 Part Numbers [Re: Alaska_A12] #14310
08/03/05 12:25 AM
08/03/05 12:25 AM
VA
RapidRunner Offline
RapidRunner  Offline
VA
Just keeping this within the search time frame.
Who knows? The Shadow Knows! But he ain't on this fraking forum! "This restoration is a test,, It is ONLY a test, Had this been an actual Restoration I would have received instructions on what to do and where to get the MONEY!" -------------------------------
Re: A12 Part Numbers [Re: RapidRunner] #14311
08/03/05 12:40 AM
08/03/05 12:40 AM
Harleysville PA
Harleysville PA
No longer able to edit the previous part list post so here's an updated, numeric order version.
Please correct or add where necessary (not sure about fuel pump and a few others).
Still waiting on PNs for many items. PM if you have some. Thanks
2421173 dual points set
2785434 fan shroud
2806216 fan belt
2806270 oil pump
2808577 master cylinder (manual drums)
2808622 PCV
2822461 horn relay
2842940 Super Bee (3M reflective) black quarter panel decal (R)
2842941 Super Bee (3M reflective) black quarter panel decal (L)
2842952 Super Bee (3M reflective) white quarter panel decal (R)
2842953 Super Bee (3M reflective) white quarter panel decal (L)
2864463 ignition switch assembly (with ground pole)
2864464 ignition switch (without ground pole)
2892093 auto trans
2901806-7 quarter scoop molding
2935803 ignition and door lock set (3 pieces) with keys
2944169 H wheels
2944269 master cylinder package (power assist)
2983116 wiper motor
3410609 man trans
3412050 4393 (list) 50 abbreviated PN (on paper tag) both front Holley carb
3412051 4394 (list) 51 abbreviated PN (on paper tag) both rear Holley carb
3412052 4391 (list) 52 abbreviated PN (on paper tag) man center Holley carb
3412053 4392 (list) 53 abbreviated PN (on paper tag) auto center Holley carb
3412056 panel, hood Super Bee w/Six Pack
3412058 air cleaner base (with wide lip lid included)
3412411 pin (stud) holddown lock Super Bee w/Six Pack
3412415 bracket, hood retaining Super Bee w/Six Pack
3412423 call out ‘SIX PACK’ hood letters
3454390 chrome w chrome button door handle (L)
3454391 chrome w chrome button door handle (R)
3570036 Super Bee decal (circle in stripe)
602957-6 Dana 60 4:10, with 11 inch backing plates
69 Six Pack Engine/Trans Internals
2532490 camshaft sprocket 2532492 timing chain
3004535 pistons
3410208 flywheel
3420039 cam tappet
3420228 rings
3462038 camshaft
https://board.moparts.org/ubbthreads/show...rue#Post1472781
Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: M_code_Coop] #14312
10/23/06 02:16 PM
10/23/06 02:16 PM
Ohio
john55 Offline
john55  Offline
Ohio
I just tried ordering a 2806070 clutch from local dealer, that part # comes up NS1
The Plymouth Win You Over Beat Goes On
Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: john55] #14313
02/22/07 10:41 AM
02/22/07 10:41 AM
Harleysville PA
Harleysville PA
Updating the list a bit. Adding PNs for hurst OEM shifter (2461947), lift off hood (3412066), trunk mat (2879384), while including the air cleaner seal in the assembly kit PN (3412058).
Hurst PN came from an NOS unit still in the box, Hood PN came from a 1974 Mitchell Manual (btw cost was $333.30 - a lot of money in 1974), trunk mat from Paul Petcous survivor bee, and seal clarification from Terry McCannix.
Keep sending PN info whenever you come across it. THANKS!
2461947 Hurst OEM shifter mechanism (6355, 6354 on arms, 6353 on reverse arm, 6356 on front of housing)
2785434 fan shroud
2806216 fan belt
2806270 oil pump
2808622 PCV
2822461 horn relay
2879384 trunk mat
2892093 auto trans
2944169 H wheels
2946532 Holley choke (Holley's A12 PN 4364A)
2983116 wiper motor
3410605 4 speed hemi man trans
3412058 air cleaner base (with wide lip lid and seal included)
3412066 Super Bee hood
3004535 pistons
3410208 flywheel
3420039 cam tappet
3420228 rings
3462038 camshaft
Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: M_code_Coop] #14314
12/29/07 07:22 PM
12/29/07 07:22 PM
Iowa
69F6A12 Offline
69F6A12  Offline
Iowa
"3577389 wide lip orange air cleaner lid(w decals)"
Is this availible at the dealer? Does anyone know if the decals are correct for a 69?
Bob ___________________ Drive fast, take chances.
Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: 69F6A12] #14315
12/29/07 07:26 PM
12/29/07 07:26 PM
Buffalo, NY U.S.A.
MrNormsTA Offline
MrNormsTA  Offline
Buffalo, NY U.S.A.
Reproductions are available only, many times on ebay, pretty nice units for about $95-$100.
The best reproduction stickers would be from ECS automotive a sponsor on this board.
Rick.
Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: MrNormsTA] #14316
12/29/07 07:56 PM
12/29/07 07:56 PM
Iowa
69F6A12 Offline
69F6A12  Offline
Iowa
Sounds good, thanks!
Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: M_code_Coop] #14317
04/20/08 05:11 PM
04/20/08 05:11 PM
I have some NOS drip rail mouldings if anyone is interested.
Re: What Carb/dist P/N# is correct for 71 Road Runner #14318
04/23/08 08:35 PM
04/23/08 08:35 PM
Dillsburg, PA
W
Wizard Offline
Wizard  Offline
W
Dillsburg, PA
I am restoring my 71 road runner and have a build date of April 30 1971 on my data plate that is under the hood. What would be the correct P/N# carb and distributor I would want to be factory correct?
Thanks,
Wizard
Guns, God, and Country. U.S. Veteran
Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: M_code_Coop] #14319
04/23/08 09:00 PM
04/23/08 09:00 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I never read this "A12 stuff" so please explain what OTC NOS parts are
Are you saying that the above list of part numbers are available Over The Counter at any Chrysler dealer?
If so ...I would have to say I'M SHOCK
CHECK OUT MY NEW WEB SITE !
Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: anlauto] #14320
04/30/08 11:23 AM
04/30/08 11:23 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Darn i found Delco Remy DR1114421 today whats that fit?
Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: Joesixpack] #14321
04/30/08 11:24 AM
04/30/08 11:24 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
#2
Re: A12 Part Numbers/Current OTC available "NOS" parts [Re: Joesixpack] #14322
04/30/08 11:32 AM
04/30/08 11:32 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
....4 bbl engines. Those are the solenoids that I use to make my repops out of.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
