Will I be able to use my current converter? #1430287
05/04/13 07:52 PM
05/04/13 07:52 PM
Plant city fl
70Dart499 Offline OP
Plant city fl
As many know I recently sold my bigblock and am in the process of building a 340 for the Dart. I'm wanting to go to a trans brake transmission, and my question is, if I go to a SB 727, will I be able to use my same converter that I used with my bigblock that I footbraked?? If I can't, could I have the existing converter reworked and then use it?
1970 Dart Drag Car
Re: Will I be able to use my current converter? [Re: 70Dart499] #1430288
05/04/13 08:07 PM
05/04/13 08:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its all about the torque... your BB makes more torque
than most small blocks so what did the BB stall at and
what was the torque and RPM it made... most SB want
a higher stall point than a BB so its unlikely it
will work but most can be opened up and restalled
but the core size matters
Re: Will I be able to use my current converter? [Re: MR_P_BODY] #1430289
05/05/13 01:35 AM
05/05/13 01:35 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
I also would imagine you might want to take it out and get a looksie at it first before running it in a new tranny
Mike
1969 Dodge Dart Swinger
