Page 2 of 3 1 2 3
Re: project shorty [Re: 340SHORTY] #1429941
07/16/13 04:47 AM
07/16/13 04:47 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
i know lol, kind of mocked thing's up to make sure every thing was going to line up an it dose
drive fast, drive hard, DRIVE MOPAR
Re: project shorty [Re: lifted85] #1429942
07/16/13 09:05 AM
07/16/13 09:05 AM
scratchnfotraction Offline
sweet! man, that is one heck of a alt bracket!! I have the same set up off the 88 B150 318 that was non-a/c with a idler pullys where the a/c comp bolts in.
how long do you want to wager the yellow paint stays on the headers?
they do look cool engine color
now days mine are rust color, I used to paint them flat white. but in the ened it always burns off.
Re: project shorty [Re: scratchnfotraction] #1429943
07/17/13 01:32 AM
07/17/13 01:32 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
thanks scratch ya I parted out myold 90 w150 an kept a few part's glad I ept the alt bracket haha, ya IIRC the smg pump bolted to this 1 but hey who need's emission's and you are right about the header paint it will flake off but hey if will look good for a bit right hahah.. hy I do go question for a guy's how many of ya se a oil pump gasket?? I threw mine away (didn't mean to) I can pick another up to biggie but I have read an heard some don't like to use the gasket's?? the pump is a tock sealed power pump if that make's a difference..
Re: project shorty [Re: lifted85] #1429944
07/17/13 09:06 AM
07/17/13 09:06 AM
I run a gasket when I have one in hand, if not I dont run one.
either way should be no problem.
Re: project shorty [Re: scratchnfotraction] #1429945
07/17/13 09:02 PM
07/17/13 09:02 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
If you get a chance find a set of these off a 90-92 van with a LA & of course a Denso
Re: project shorty [Re: BulletBob] #1429946
07/20/13 06:01 AM
07/20/13 06:01 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
I will have to keep my eye's open for them bracket's, not a real fan of this great big 1, an I could have took the grinder to it but hey it work's.. I ended up making my own oil pump gasket, part's store said it would take 2 day's told them give me some gasket paper
Re: project shorty [Re: lifted85] #1429947
07/20/13 06:27 AM
07/20/13 06:27 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
got the motor in the truck today set the motor in, an she sat to far forward, so we pulled it back out moved the mount's on the k member to the back hole's an she is good. still got to build a cross member for the tranny, a buddy say's he might have 1, which im hoping, 1 less thing to build should be able o fire her up sunday. still need to get a driveline made, install shifter ect just little thing's lol but I will still get to hear her pur!! .......
Re: project shorty [Re: lifted85] #1429948
07/20/13 08:41 AM
07/20/13 08:41 AM
remeber, when you go BB one day you will use those other holes to mount it in the frame.
progress is good.
Re: project shorty [Re: scratchnfotraction] #1429949
07/21/13 01:37 AM
07/21/13 01:37 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
ok let me see if I got this right the slant 6 sat in the front hole's on the k-frame which that's how the mount's where when we swapped them to the rear whole's like they are now... was I supposed to leave the k-frame mount's alone???
Re: project shorty [Re: lifted85] #1429950
07/21/13 02:16 AM
07/21/13 02:16 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Its got 2cylinders more in a row so its longer
Re: project shorty [Re: 76dodgeboy] #1429951
07/23/13 05:02 AM
07/23/13 05:02 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
a know lol I was not sure if I was supposed to mount the 318 in the first set of hole's or 2nd on the k-frame??? it's mounted to the 2 right now so look's like that's where she is staying.. got the cross member for the tranny in, pulled the cross member out of my parts 74 power wagon w200, she bolted up but need to fab up the 2 bracket's that mount to the bottom of the frame, the 1's I got are about 2-3" to long got the core support sanded, tomorrow will be sanding down the rest of the inside of the front clip an painting it.. also what's your guy's thought's on the ol $50 rustoleum roll on paint job?? I seen a few pic's of car's done with it an they don't look bad, I wont be able to afford a real paint job this year but wouldn't mind getting rid of this yellow..
Re: project shorty [Re: lifted85] #1429952
07/31/13 02:38 AM
07/31/13 02:38 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
hey guy's little update, found a set of tranny line's at a junk yard, was going to build my own bt for $55.00 each I passed an found a set at the J/Y for $10.00 I painted the inside of the cab tonight, I went to install the new oil dip stick tube (mr gasket) broke that trying to get it in so off to the J/Y tomorrow to get a stocker.. got the header's on, that was kind of a pain but it's done .. I do got a question on the drive line, I bolted the drive line up tonight an every thing fit's but on the slip yoke there maybe 1/2" to a 1" of travel that enough or do I need to get the drive line cut??
Re: project shorty [Re: lifted85] #1429953
07/31/13 09:45 AM
07/31/13 09:45 AM
slip yoke built into the drive shaft or slip yoke like a auto/4-speed?
is that a 1/2 to 1 from botooming out or comeing apart?
front rear shaft?
Re: project shorty [Re: lifted85] #1429954
07/31/13 07:28 PM
07/31/13 07:28 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Hey Lifted do you still have the inspection cover for the tranny? My brother inlaw just picked up a Rancharger with a 4spd and its missing the inspection cover. Pm me with details on price if you have it. Thanks
Keep up the good work. youll be burning rubber in no time
Re: project shorty [Re: 76dodgeboy] #1429955
08/01/13 12:22 AM
08/01/13 12:22 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Inspection covers are overrated. I haven't used one for years on various different vehicles.
Re: project shorty [Re: scratchnfotraction] #1429956
08/01/13 05:00 AM
08/01/13 05:00 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
front rear shaft?
slip yoke like a auto/4spd you slide the slip yoke on the spline's.. I think it's to long, there is maybe 1/2" of travel from the slip yoke to the drive line, now what I was thinking is maybe cutting 1/2" off the spline's on the drive line, I don't want to cut 1/2 of the drive line it's self an weld it back up ect, I talked to a drive line shop an said they have done this before.. what do you guy's think?? an 76 I used the inspection plate but I think I got another let me dig around..
Re: project shorty [Re: lifted85] #1429957
08/01/13 11:52 AM
08/01/13 11:52 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Ok. Thanks
Re: project shorty [Re: 76dodgeboy] #1429958
08/01/13 05:26 PM
08/01/13 05:26 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
When the driveshaft is bolted in you want 3/4" to 1" of slip...
I am truckless..
Re: project shorty [Re: 340SHORTY] #1429959
08/11/13 04:06 AM
08/11/13 04:06 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
well guy's an gal's I fired her up a few day's ago an boy dose she sound good!! today I installed the quick silver shifter an cable, picked up some heat tape from ace hardware rated at 600 deg wrapped the cable an also built a heat shield for some extra insurance.. had to replace the freeze plug on the driver's side head I had to put a heli coil in the last headerbolt an ran the drill in the side of it, didn't notice tell I filled it up with water but got that replaced wasn't to bad. think I need to double gasket the header's, I feel a little air comin out of them but easy fix.. only thing's left are to drop a seat into it, inner fender, grill, drive line, an a few odd's an end's like lowering it.. but man am I happier than a bull in a china shop!!!
Re: project shorty [Re: lifted85] #1429960
08/12/13 10:02 AM
08/12/13 10:02 AM
Dearborn, Michigan
jstollfu Offline
jstollfu  Offline
Dearborn, Michigan
Save the hassle of the double gaskets. Pick up a set of the Remflex gaskets. Look them up.. The best exhaust gasket I've ever used.
Page 2 of 3 1 2 3
