Re: 47 Dodge pickup is done
[Re: Lefty]
#1429835
05/03/13 08:58 PM
05/03/13 08:58 PM
moparpollack
Lil Herman
Lil Herman
85086
Two questions: where did you mount the battery box? How's the coronet coming along?
[Re: moparpollack]
#1429838
05/06/13 09:26 AM
05/06/13 09:26 AM
Posts: 2,833 Ontario Canada
Webster
Ontario Canada
Under passenger floor?
[Re: Webster]
#1429839
05/06/13 10:55 AM
05/06/13 10:55 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
What's up with the cheby......are going to put a mopar motor in it? Please say yes.
Moparlee
[Re: Robbins]
#1429840
05/06/13 06:42 PM
05/06/13 06:42 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
What's up with the cheby......you are going to put a mopar motor in it? Please say yes.
I was thinking the same thing except, you had it that far apart(and did some really nice work) but did not change to a mopar engine at that time
Oh well I feel a mopar deserves a mopar in it
[Re: moparpollack]
#1429845
05/26/13 07:09 PM
05/26/13 07:09 PM
Posts: 6,516 Santa Cruz, California
Lefty
Howdy!
The battery box was a copy of the rusted out stock box. It mounts to the floor under the seat right below where the passengers heiney would be.
The Coronet is sitting in the back of the shop on jack stands collecting dust and cat hair. I've been working on Mopars for others to be able to buy parts for it. After I finish the 68 Charger I'm currently building for a friend, this stuff is going on my Coronet -
A Tremic TKO 600 5 speed is on a dolly under the Coronet waiting to be bolted in using a kit From American Powertrain.
I have 2" drop spindles assembled with Wilwood 12.19" rotors and 6 piston calipers in a box waiting to be bolted in up front.
I have a pair of 440 Source aluminum heads waiting in the box to be bolted on.
To go with the heads and stick shift I have a new Quick Fuel Q750 (double pumper).
I've cut open the rear sub frames and fitted 2" X 3" .120" wall rectangle tubing to connect to the front crossmenber.
I'm hoping to get back to working on the Coronet in a month or two.
How's life on your end of the state?
[Re: Robbins]
#1429846
05/26/13 07:12 PM
05/26/13 07:12 PM
Lefty
I'd have a 440 in it if it were my truck. It's a friends truck he inherited from his Grandfather. The motor was in OK condition and he did not understand the need for having a Mopar in a Mopar.
