440 Alternator #1429830
05/03/13 08:19 PM
05/03/13 08:19 PM
middle of the country
aar1 Offline OP
aar1  Offline OP
1970 Cuda, 440 auto, A/C, 4-bbl.... if the car is running, should it stay running if you disconnect the battery? My car dies when I try it and the alternator supposedly checks out fine. Thoughts? Thanks!!
Re: 440 Alternator [Re: aar1] #1429831
05/03/13 08:27 PM
05/03/13 08:27 PM
Thoughts?
Yes if the alt is putting out it would say running but it ain't recommended to check it that way as is stresses the alt (I believe). Since the alt checked out Ok I'd check the field circuit/connections for continuity/power & the reg also as needed. Need switched 12V to one field (blue wire) then continuity in/thru/out the other brush assy then the green wire to the reg & the reg grounds it as needed thru the case to ground.
Re: 440 Alternator [Re: RapidRobert] #1429832
05/03/13 08:33 PM
05/03/13 08:33 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yup should run. If it's not, check the voltage regulator and follow the wires. May just be a broken wire somewhere.
Re: 440 Alternator [Re: DaytonaTurbo] #1429833
05/03/13 09:20 PM
05/03/13 09:20 PM
IN
ahy Offline
ahy  Offline
IN
A better (and simple) test of the charging system is to fast idle the engine and check voltage at the battery. It should be over 13V and best is 13.5 to 14.3 or so. If its under 13 volts the charging system is not working properly.
At slow idle voltage may drop as alternator output drops way off at low revs.
With low idle output of the standard alternator, the pull off the cable test may give false results... plus its really hard on any electronics like the ignition module.
