Re: 68 gtx door gap???
[Re: notforsale440]
#1429663
05/03/13 10:38 PM
05/03/13 10:38 PM
68gtx
[Re: 68gtx]
#1429664
05/03/13 11:05 PM
05/03/13 11:05 PM
Posts: 162 nj
notforsale440
nj
no problem........and oh, start with a good/new set of door hinges, no saggers............ line up doors with the strikers REMOVED....... upon final assembly, adjust the striker to the door; don't allow the striker to "support" the door or pull it into position
[Re: sthemi]
#1429667
05/04/13 02:12 AM
05/04/13 02:12 AM
Posts: 7,066 portland or
new bee
Richard Cranium
Richard Cranium
portland or
Larry, keep in mind a fully assembled door will weigh more than the shell. We set the gaps and other adjustments on my Super Bee with an empty door, only to find later that many of the adjustments were way off once the door was fully assembled. If you can, weigh down the door as if it was fully put together prior to seting up the strikers, gaps and so forth.
*1969 383 4sp. Super Bee *1966 Alfa Romeo Giulia Sprint GT *1965 Porsche 356C *2004 VW Passat Wagon *2004 Mini Cooper S *1967 Jaguar E-Type FHC
A mall cop is in our midst.
[Re: 68gtx]
#1429669
05/04/13 01:30 PM
05/04/13 01:30 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
You don't want the gaps too tight because once painted, that gap gets smaller and could get chipped.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
