So my FBO ECU crapped out..... #1429380
05/02/13 08:40 PM
05/02/13 08:40 PM
Willoughby Hills, Ohio
gd9704 Offline OP
super gas
gd9704  Offline OP
super gas
....and I threw a spare orange box ecu in to bring the car back to life. Any reason why I can't just run an orange box with the rest of the FBO system? (It's the older version that used a 2 lead ballast resistor.)
Thanks!
Re: So my FBO ECU crapped out..... [Re: gd9704] #1429381
05/02/13 08:47 PM
05/02/13 08:47 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I did the same thing, but my FBO coil eventually died too. I don't know if the orange box had something to do with it, or if it was just from age (6 years) or use.
Re: So my FBO ECU crapped out..... [Re: gd9704] #1429382
05/02/13 10:17 PM
05/02/13 10:17 PM
I think they're compatible enough. I run a older black FBO coil with a stock 4 pin ECU/single .25 ohm MP race ballast & it starts instantly hot or cold which tells me that it is a compatible system. I do carry spares tho
Re: So my FBO ECU crapped out..... [Re: RapidRobert] #1429383
05/03/13 12:29 AM
05/03/13 12:29 AM
dogdays Offline
dogdays  Offline
An orange box is just a switch. How could it hurt a coil? Supposing it isn't stuck in the "ON" position, how could it be the culprit?
I have a sneaking suspicion that FBO has had some quality problems too. Just don't tell Don that!
R.
Re: So my FBO ECU crapped out..... [Re: gd9704] #1429384
05/03/13 12:59 AM
05/03/13 12:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks!
Other than the orange box being a POS ... if it's something built after the year 2000 anyway ... The current orange box pulls out timing above 4000 rpm . If you drive like your grandma going to sunday mass that may not be a problem ...
Re: So my FBO ECU crapped out..... [Re: dogdays] #1429385
05/03/13 01:27 AM
05/03/13 01:27 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The old FBO boxes had failures which had a lot of people waiting while he redesigned them. There were numerous complaints of people waiting for months for replacement boxes,but now he sells something completely different
Keith
Re: So my FBO ECU crapped out..... [Re: JohnRR] #1429386
05/03/13 08:50 AM
05/03/13 08:50 AM
gd9704 Offline OP
super gas
gd9704  Offline OP
super gas
Thanks!
Lol...I must be getting old....anymore, I don't worry so much about max performance, I just want the thing to run!
Re: So my FBO ECU crapped out..... [Re: gd9704] #1429387
05/03/13 09:09 AM
05/03/13 09:09 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks!
Me too...
I have already gone really fast in TADs and no street strip car is going to impress me.
I installed a 30 year old stock box a couple years ago and I swear it runs better than the chrome box I took off.
I'm digging the reliability nowadays. I keep my cars simple and they still run great with eddie heads and more. No fancy electric fuel pumps or stuff like that.
Re: So my FBO ECU crapped out..... [Re: gd9704] #1429388
05/04/13 01:56 AM
05/04/13 01:56 AM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Almost makes running points look good.
Re: So my FBO ECU crapped out..... [Re: gd9704] #1429389
05/04/13 01:59 PM
05/04/13 01:59 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
Thanks!
my ecu crapped out too, i went back to the chrome box...
Re: So my FBO ECU crapped out..... [Re: Dakota_Don] #1429390
05/04/13 04:44 PM
05/04/13 04:44 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
Are there any methods to determine pre 2000 ECU such as date code?
Semper Fi
Re: So my FBO ECU crapped out..... [Re: Dakota_Don] #1429391
05/04/13 04:56 PM
05/04/13 04:56 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Thanks!
Talking about chrome boxes, I have to use one because the FBO ones won't let the MSD rev limiter work. Kinda hard on valves and springs!!!
Never had any box actually fail yet...Mopar,FBO, or generics. Guess I'm just lucky.
Re: So my FBO ECU crapped out..... [Re: GOLDMYN] #1429392
05/05/13 01:45 PM
05/05/13 01:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there probably is but it seems that even the pre 2000 orange box also pulls out timing over 4k rpm , do your self a favor and just install something else ...
Re: So my FBO ECU crapped out..... [Re: JohnRR] #1429393
05/05/13 07:16 PM
05/05/13 07:16 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Yes... They're orange...!
Best to leave all the orange ones at the stores.
Or, paint your favorite aftermarket ECU orange...
When it comes to the orange ECU's...
Life sure is like a box of chocolates... You never know when you'll get stranded...
