What rods to use; 4.25" stroke Hemi #1429093
05/02/13 09:07 AM
05/02/13 09:07 AM
Netherlands
72Challenger Offline OP
Netherlands
Have a stock bore 426 block and a Eagle 4.25 stroke (part# 444242507100) crank for it.
Now need to sort out which rods and pistons to use for a final compression of around 10:1
Any input? Greatly appreciated!
Re: What rods to use; 4.25" stroke Hemi [Re: 72Challenger] #1429094
05/02/13 10:02 AM
05/02/13 10:02 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
A LONG ROD LIKE 7.1 IS VERY POPULAR. IT ALLOWS A SHORTER AND LIGHTER PISTON
home of the
Sox and Martin Hemi Duster
Re: What rods to use; 4.25" stroke Hemi [Re: HEMIFRED] #1429095
05/02/13 10:09 AM
05/02/13 10:09 AM
an8sec70cuda Offline
Just ordered a set of 7.100" BBC Molnar Technologies rods from Dan at Performance Only for a 540" Hemi I'm working on.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What rods to use; 4.25" stroke Hemi [Re: an8sec70cuda] #1429096
05/02/13 11:56 AM
05/02/13 11:56 AM
California
mickm Offline
mickm  Offline
California
the rods in my engine are 7.100 that i got from tim banning at FHO. it is a 4.25 stroke. i don't even know the brand name, as he has them skinned for him!
Re: What rods to use; 4.25" stroke Hemi [Re: mickm] #1429097
05/02/13 10:34 PM
05/02/13 10:34 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
7,1 and 4.25 stroke is a nice combination....pistons might have to be custom ordered....diamond makes good pistons and they prices are good.
Re: What rods to use; 4.25" stroke Hemi [Re: 72Challenger] #1429098
11/07/13 10:48 AM
11/07/13 10:48 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Just took delivery of an old hemi that was used and abused in racing service. Looking to get it put into my street car. I was doing some searching and came across this thread. So I figured I hijack and build upon it. Can you use a 4.25 strok crank in on of the MP blocks? I need to replace the block, but looking to use the rotating assembly heads and intake off the race motor. Thanks.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: What rods to use; 4.25" stroke Hemi [Re: RoadRunner] #1429099
11/07/13 01:37 PM
11/07/13 01:37 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I'd go 7.1 with a .990 pin...try to get that heavy Hemi piston as light as possible and the rod ratio will benefit the high piston speeds with the tall 10.72" deck.
On an RB 10.72 deck wedge it's not as critical and a 6.7-6.86 rod is fine , on a hemi go for the longer rod
WIZE
In Car:
Re: What rods to use; 4.25" stroke Hemi [Re: Streetwize] #1429100
11/07/13 03:00 PM
11/07/13 03:00 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I also have a 4.250 stroke crank for my 488 hemi......can you get a piston with low enuff compression to use a 7.1 rod with a blower?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: What rods to use; 4.25" stroke Hemi [Re: toplescuda] #1429101
11/07/13 03:58 PM
11/07/13 03:58 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Toples...
I would think so, even with a 7.1 rod and a 4.25 you're still gonna have close to a 1.5" compression height piston, That'll be be GRACIOUS PLENTY to get enough of a dish to run low compression for Boost.
WIZE
In Car:
Re: What rods to use; 4.25" stroke Hemi [Re: Streetwize] #1429102
11/07/13 04:13 PM
11/07/13 04:13 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Now just need to fig out what final compression i need
1971 charger
Re: What rods to use; 4.25" stroke Hemi [Re: toplescuda] #1429103
11/07/13 04:49 PM
11/07/13 04:49 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
I'v been laying this off on mine with a 4.5 stroke. With a 6.86 rod the pin is almost out the bottom of the cylinder with alot of the skirt also. So I would go with the longer rod to keep the rocking down.
