What rods to use; 4.25" stroke Hemi
#1429093
05/02/13 09:07 AM
05/02/13 09:07 AM
Posts: 1,262 Netherlands
72Challenger
Netherlands
Have a stock bore 426 block and a Eagle 4.25 stroke (part# 444242507100) crank for it.
Now need to sort out which rods and pistons to use for a final compression of around 10:1
Any input? Greatly appreciated!
Re: What rods to use; 4.25" stroke Hemi
[Re: 72Challenger]
#1429094
05/02/13 10:02 AM
05/02/13 10:02 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
A LONG ROD LIKE 7.1 IS VERY POPULAR. IT ALLOWS A SHORTER AND LIGHTER PISTON
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#1429095
05/02/13 10:09 AM
05/02/13 10:09 AM
Posts: 13,390 Marion, South Carolina [><]
an8sec70cuda
Just ordered a set of 7.100" BBC Molnar Technologies rods from Dan at Performance Only for a 540" Hemi I'm working on.
[Re: 72Challenger]
#1429098
11/07/13 10:48 AM
11/07/13 10:48 AM
Posts: 5,140 East Aurora (Buffalo) NY
RoadRunner
Just took delivery of an old hemi that was used and abused in racing service. Looking to get it put into my street car. I was doing some searching and came across this thread. So I figured I hijack and build upon it. Can you use a 4.25 strok crank in on of the MP blocks? I need to replace the block, but looking to use the rotating assembly heads and intake off the race motor. Thanks.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#1429099
11/07/13 01:37 PM
11/07/13 01:37 PM
Posts: 9,888 Weddington, N.C.
Streetwize
Weddington, N.C.
I'd go 7.1 with a .990 pin...try to get that heavy Hemi piston as light as possible and the rod ratio will benefit the high piston speeds with the tall 10.72" deck. On an RB 10.72 deck wedge it's not as critical and a 6.7-6.86 rod is fine , on a hemi go for the longer rod
[Re: Streetwize]
#1429100
11/07/13 03:00 PM
11/07/13 03:00 PM
Posts: 8,857 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I also have a 4.250 stroke crank for my 488 hemi......can you get a piston with low enuff compression to use a 7.1 rod with a blower?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: Streetwize]
#1429102
11/07/13 04:13 PM
11/07/13 04:13 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Now just need to fig out what final compression i need
