Re: driveshaft spins wheels do not move. [Re: RapidRobert] #1429059
05/04/13 07:47 PM
05/04/13 07:47 PM
Rockford,IL
71Polara383 Offline OP
Rockford,IL
I found out the bearings still weren't down far enough got the passenger side done after work and just to see if it helped any I set the car back down and tried to move it still nothing. Keep in mind I didn't press the bearing down on the drivers side yet. Would the car move with only one axle touching the inner splines?
Re: driveshaft spins wheels do not move. [Re: 71Polara383] #1429060
05/04/13 07:49 PM
05/04/13 07:49 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not very well.. If the surefrip is good it will try to move but it'll be hard on the clutches & it won't move much.....
Re: driveshaft spins wheels do not move. [Re: 1_WILD_RT] #1429061
05/05/13 08:37 AM
05/05/13 08:37 AM
Rockford,IL
Rockford,IL
Got the axle bearing on the driver side all the way down, popped the axle back in and IT WORKS!!!!!! The axles were not catching the inner splines like many of you guys had said. Had to check and make sure both tires were spinning correctly! The 3:91s lit the roller tires right up (235/75 All terrains) and thats with the lean burn acting like well... lean burn. Time to move onto the engine and trans now! Thanks Moparts!
Re: driveshaft spins wheels do not move. [Re: 71Polara383] #1429062
05/05/13 10:45 AM
05/05/13 10:45 AM
& the punkin didn't even have to come out
