driveshaft spins wheels do not move. #1429039
05/02/13 12:50 AM
05/02/13 12:50 AM
Rockford,IL
71Polara383 Offline OP
Rockford,IL
Swapped a 8 3/4 into my Doba. Bought a 3:91 sure grip in a 657 case. Clutch style sure grip unit. Got it on the ground and it won't move. I looked under the car and the driveshaft spins. I jacked up the rear end enough to get the tires off theground and put it drive and it works fine. What's goin on? It was supposed to be rebuilt but I have no proof and the seller claims it worked when pulled. I'm upset and annoyed. Please help.
Re: driveshaft spins wheels do not move. [Re: 71Polara383] #1429040
05/02/13 12:52 AM
05/02/13 12:52 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Take it apart, pay attention & you will find a problem...
Re: driveshaft spins wheels do not move. [Re: 71Polara383] #1429041
05/02/13 01:29 AM
05/02/13 01:29 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Possible causes:
1. Axles are too short to reach inner side gear splines
2. Axle splines and/or side gear splines are stripped
3. Side gear teeth and/or spider gear teeth are broken
Are you running aftermarket axles?
Re: driveshaft spins wheels do not move. [Re: DoctorDiff] #1429042
05/02/13 02:20 AM
05/02/13 02:20 AM
Rockford,IL
Rockford,IL
Running stock axles. Axles match the housing. Are sure grip axles any different than standard open axles? I don't think they are but I'm looking into any possible reason.
Re: driveshaft spins wheels do not move. [Re: 71Polara383] #1429043
05/02/13 02:28 AM
05/02/13 02:28 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
All 8.75" axle lengths were standardized after 1964.
Your axle is probably not engaging the innermost side gear. This could be due to stripped splines, or a severely bent bearing retainer.
Are you running OEM wheel bearings, or Green wheel bearings?
Did both axles install easily?
Re: driveshaft spins wheels do not move. [Re: DoctorDiff] #1429044
05/02/13 06:28 AM
05/02/13 06:28 AM
Rockford,IL
Rockford,IL
Green bearings. And yes they popped in fairly easy. Got home from work a little early, gonna go and pull an axle and see whats going on.
Re: driveshaft spins wheels do not move. [Re: 71Polara383] #1429045
05/02/13 08:04 AM
05/02/13 08:04 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
maybe put white lithium grease on the axle shaft splines so you can "read" what's gong on when you slip them into the diff?
**Photobucket sucks**
Re: driveshaft spins wheels do not move. [Re: 70Cuda383] #1429046
05/02/13 08:22 AM
05/02/13 08:22 AM
Rockford,IL
Rockford,IL
Pulled the axles. All looked normal. One side was tapered a little bit and the bearings arent pressed all the way down. (1/16th of an inch from being seated) So I got them down as far as I could. Put it all back together and still nothing. This Pumpkin is shot. Thats all i can think of. I used a white grease marker and checked to make sure the axles were going all the way in and sure enough they are making contact. Anybody else got any ideas. Next up is to put the 3:23 open back in and see if it does the same thing.
Re: driveshaft spins wheels do not move. [Re: 71Polara383] #1429047
05/02/13 08:47 AM
05/02/13 08:47 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
sounds like you got took,just pull the punkin an get it over with,GOOD LUCK.
Re: driveshaft spins wheels do not move. [Re: 71Polara383] #1429048
05/02/13 11:22 AM
05/02/13 11:22 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If the Green wheel bearings are seated, the distance from the snap-ring to the outisde face of the axle flange will measure 2.4".
The axles will always engage the first set of clutch hub splines, but the hidden inner side gear splines are often stripped. These inner splines drive the vehicle.
Open differentials do not have this problem.
Re: driveshaft spins wheels do not move. [Re: DoctorDiff] #1429049
05/02/13 11:38 AM
05/02/13 11:38 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And here's a picture to show the double splines the good Dr is describing... BTW Doc has new gears...
Re: driveshaft spins wheels do not move. [Re: 1_WILD_RT] #1429050
05/02/13 12:50 PM
05/02/13 12:50 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
My guess: side gears in diff. are sheared. DAMHIK.
Re: driveshaft spins wheels do not move. [Re: 1_WILD_RT] #1429051
05/02/13 02:44 PM
05/02/13 02:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Could be that the axles are not engaging the inner splines of the side gears ?
It's a 657 chuck which is the pre 741 , does it have the early clutch type suregrip in it from a rear with tapered axles ? Which may require a longer axle ???? I remember john K. posting something about the early rears having a different thrust width ????
If the axle isn't engaging the inner splines then the problem the OP is having can happen , doesn't necessarily mean the chuck is bad. A change of the side gear and the correct thrust spacing would fix it ?
Re: driveshaft spins wheels do not move. [Re: JohnRR] #1429052
05/03/13 12:31 AM
05/03/13 12:31 AM
dogdays Offline
dogdays  Offline
I vote for a broken pinion.
R.
Re: driveshaft spins wheels do not move. [Re: dogdays] #1429053
05/03/13 08:50 AM
05/03/13 08:50 AM
Wattsburg, Pa
Dr V Offline
Dr V  Offline
Wattsburg, Pa
R.
My thoughts too....
69 1/2 A12 BEE 4 spd
1968 Charger 383
1970 Roadrunner 440+6 Survivor
2019 Redeye
2005 FORD GT Red/White
2017 Viper ACR Extreme Red/White
1979 Branco Red/Red
2018 Porsche GT3 Miami
1971 440+6 Cuda 4 speed V2
2020 Sebring Orange Vette
1979 Chevy Boogie Hippie Van
Re: driveshaft spins wheels do not move. [Re: Dr V] #1429054
05/03/13 09:40 AM
05/03/13 09:40 AM
Beans Cove Pa
Bumbalawski Offline
Bumbalawski  Offline
Beans Cove Pa
If it has the clutch type sure grip unit, the clutches are toast. You can buy rebuild kits for them for around $70.
Re: driveshaft spins wheels do not move. [Re: Bumbalawski] #1429055
05/03/13 10:02 AM
05/03/13 10:02 AM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
If the clutches are shot it will still move.
Re: driveshaft spins wheels do not move. [Re: BRONZEBEE] #1429056
05/03/13 10:39 AM
05/03/13 10:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
bad clutches just turn it into a one wheel wonder
Re: driveshaft spins wheels do not move. [Re: JohnRR] #1429057
05/03/13 10:50 AM
05/03/13 10:50 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: driveshaft spins wheels do not move. [Re: bonefish] #1429058
05/03/13 10:51 AM
05/03/13 10:51 AM
PLEASE, I cant stand the suspense
