Donīt know the answer to your question, but before trying to open them up,have you checked the three headlight relays on the far right side of the bulkhead in front of and slightly below the glove box?
The center one is the control relay, and on the right is the opening relay. The relay on the left is the closing relay. The opening and closing relays are interchangeable.
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
