Edlebrock CH4B Intake manifold question #1428104
04/30/13 01:31 PM
04/30/13 01:31 PM
Indy
N
Nuke463 Offline OP
Nuke463  Offline OP
N
Indy
Can an Edlebrock CH4B aluminum Intake manifold be used on a 383? I was told that they are not interchangeable with use on a 440? Anyone know?
Nuke
Re: Edlebrock CH4B Intake manifold question [Re: Nuke463] #1428105
04/30/13 01:41 PM
04/30/13 01:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Way to wide.
Re: Edlebrock CH4B Intake manifold question [Re: Nuke463] #1428106
04/30/13 01:51 PM
04/30/13 01:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The CH4B is a 440 intake , the only way it would fit on a 383 is if the 383 had mopar performance stage 6 heads on it .
Re: Edlebrock CH4B Intake manifold question [Re: Nuke463] #1428107
04/30/13 02:42 PM
04/30/13 02:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
383/400 takes a DP4B.
Re: Edlebrock CH4B Intake manifold question [Re: 62maxwgn] #1428108
04/30/13 06:20 PM
04/30/13 06:20 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
And about the only difference between it and a stock iron one is the weight.
Kevin
Re: Edlebrock CH4B Intake manifold question [Re: Twostick] #1428109
04/30/13 07:55 PM
04/30/13 07:55 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Kevin
You're wrong on that one!
Re: Edlebrock CH4B Intake manifold question [Re: 62maxwgn] #1428110
04/30/13 08:46 PM
04/30/13 08:46 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Kevin
Good manifold.
Re: Edlebrock CH4B Intake manifold question [Re: MoparforLife] #1428111
04/30/13 09:21 PM
04/30/13 09:21 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
And from all the dyno tests i have seen its not any better then a Edelbrock Performer Intake , maybe a couple horsepower at best - So why would anyone spend the time and money on a used DP/CH Intake and not knowing what your getting as far as its been milled or heli-coils etc. when you can get the Performer or Performer RPM brand new ???
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Edlebrock CH4B Intake manifold question [Re: bee1971] #1428112
04/30/13 10:35 PM
04/30/13 10:35 PM
Maryland USA
beatgoeson Offline
beatgoeson  Offline
Maryland USA
Ch4B will fit under a stock hood with a factory air cleaner , an RPM won't . thats one big reason for me.
Re: Edlebrock CH4B Intake manifold question [Re: beatgoeson] #1428113
04/30/13 11:05 PM
04/30/13 11:05 PM
dogdays Offline
dogdays  Offline
To the OP:
NO, you cannot use it on a 383 or 400. It is too wide.
If you had a 413, 426 wedge or 440, it would and it would be better than a stock intake, regardless of others' opinions.
However, for you, the DP4B is about equivalent. Or a Performer.
Actually, there was an exhaustive 383 intake manifold test with more than 10 intakes, find it and go.
R.
Re: Edlebrock CH4B Intake manifold question [Re: Nuke463] #1428114
05/01/13 02:38 AM
05/01/13 02:38 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
Could be used on a RB 383 if you had one, not too many of the 383 RB's around though.
Re: Edlebrock CH4B Intake manifold question [Re: bee1971] #1428115
05/01/13 03:32 AM
05/01/13 03:32 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
That would be incorrect ; the "performer" is basicly a stock replacement manifold that performs at the same level as a stocker. The RPM is better but it can create hood clearance issues with some cars...requiring drop base air cleaners & modified throttle/kickdown linkage.
The CH4B on the other hand performs like an RPM but doesn't have all the installation headaches.
Here's a good dyno shootout to look at :
http://www.moparmusclemagazine.com/techa...st/viewall.html
Ron
Re: Edlebrock CH4B Intake manifold question [Re: firefighter3931] #1428116
05/01/13 03:36 AM
05/01/13 03:36 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
.... if all these dyno tests are right .... WHY didn't Eddy just copy the old design with some new cosmetic diffs and sell it that way?
Re: Edlebrock CH4B Intake manifold question [Re: firefighter3931] #1428117
05/01/13 05:24 AM
05/01/13 05:24 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Ron
First of all where talking about the 383 here , not the 440 in that test - Also the Performer WASNT in that test you posted - Also in that test the Performer Rpm makes a positive torque difference down low compared
Again 383 , and the Performer wasn't in that test
NEXT
Siberian Huskies
Re: Edlebrock CH4B Intake manifold question [Re: dOc !] #1428118
05/01/13 05:44 AM
05/01/13 05:44 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
If you study the torque & HP #'s the Perf. RPM is better overall than the CH4B. With a higher peak HP at a lower rpm.
And to answer your question...........the taller newer design is aestetically better looking for marketing too.
The CH4B is a great intake for a stealth underhood upgrade over the heavy cast iron. I'd use one.
Re: Edlebrock CH4B Intake manifold question [Re: bee1971] #1428119
05/01/13 05:53 AM
05/01/13 05:53 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
The Hot Rod Test of the 383 Intakes - The DP4 versus the Performer (Stock Factory Intake Was Not In That Test)
From what I remember there was like 1 ft lb difference between the two and something like 4-5 hp WOW !!!
And personally I have seen dyno numbers on both intakes and they where within a few hp either way on a mildly built 383 - Apples to Apples
HOT ROD
You'll also see that there's a group of single-planes that are virtually identical (the M1, Street Dominator, and TM6) and some dual-planes that also tested very closely (the Action Plus, DP4B, and Performer). The numbers are so close that you would never know the difference in a car.
The Performer RPM will more clearly outrun the other dual-planes and the differences among the single-planes will become more distinct.
Siberian Huskies
Re: Edlebrock CH4B Intake manifold question [Re: bee1971] #1428120
05/01/13 05:59 AM
05/01/13 05:59 AM
Holly/MI
Holly/MI
"mildly built 383" being the key element here. Now add a lot more cam compression, carb, better exhaust and see which prevails.
I have a SB Perf. and an old LD4B, flip them over and look at the cast runners and huge difference. The Perf. looks like it would be lucky to hit 5k rpm. Which was OK back in the day when it was designed for its intended market.
Re: Edlebrock CH4B Intake manifold question [Re: Dean_Kuzluzski] #1428121
05/01/13 06:41 AM
05/01/13 06:41 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Thread from 2007 on this whole 383 Intake
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Siberian Huskies
Re: Edlebrock CH4B Intake manifold question [Re: Dean_Kuzluzski] #1428122
05/01/13 06:50 AM
05/01/13 06:50 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Maybe we need to bee more specific on the BUILD of the motor when talking intakes
But in all fairness , if I am building a Serious 383 or 440 with all the goodies , aluminum heads blah blah blah etc. are you seriously going to go out of your way to find a DP4 Intake to stick on top of it , really
Siberian Huskies
Re: Edlebrock CH4B Intake manifold question [Re: Dean_Kuzluzski] #1428123
05/01/13 06:56 AM
05/01/13 06:56 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
DeanO ..... what I meant to compare it to was the regular Performer intake .... if I was Eddy ... I would have copied the base CH4B .... and then tweated it .... BUT they didn't.
Eddy does some things "funny" anyways .... a couple of years ago I asked them for some info on both the SP2P and the Streetmaster and they said they knew ZIP about it.
INTERESTING ....even though I made it plain that I was buildiing a low rpm torque motor with MPG in-mind with a spreadbore carb ...
