any sure fixes on leaky brake master cyl. lid? #1428016
04/30/13 01:45 AM
04/30/13 01:45 AM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
Ive always had bad luck with leaky master cylinders. I will tighten the bail to ensure a great tight fit, and darn it, fluid still will come out of the top. This past restoration I took the master cyl, and out of the truck, fliped it and sanded the surface on a flat board with sand paper to ensure that it was true. With a new chrome lid on it, the thing leaks like crazy, I have to keep it only 3/4 full at most, and I still get some coming out.
Any sure fixes for this problem on mopars cast iron dual master cylinders? If not, someone needs to invent something.
fish
Re: any sure fixes on leaky brake master cyl. lid? [Re: RonaldV] #1428017
04/30/13 01:54 AM
04/30/13 01:54 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
A board is anything but flat , try it on a formica counter or better yet a surface plate.
Loose the chrome cover .
Re: any sure fixes on leaky brake master cyl. lid? [Re: JohnRR] #1428018
04/30/13 04:07 AM
04/30/13 04:07 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
I have dealt with the same thing with my 72 Duster. I've tried different covers, different rubber seals, different spring retainers. My brakes work fantastic, but the seeping fluid is annoying. The machined surface on my M/C isn't pitted either.
Re: any sure fixes on leaky brake master cyl. lid? [Re: Jjs72D] #1428019
04/30/13 09:13 AM
04/30/13 09:13 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I got sick of this too with the factory cast cylinder. Makes it impossible to keep it painted and looking somewhat nice.
Probably not what you are going to want to do but just throwing it out there. I went with the aluminum MP 2 bolt master cylinder with the screw on caps/rubber seals and stays pretty dry if you don't ovefill the resevoir. Also, resevoir is plastic and body is cast aluminum so no rust!
This and the 4 bolt-2bolt adapter plate and it bolted right on to the OEM booster.
Re: any sure fixes on leaky brake master cyl. lid? [Re: cjskotni] #1428020
04/30/13 03:02 PM
04/30/13 03:02 PM
Owosso, Michigan
stateroadhog Offline
Owosso, Michigan
I had same problem just added another gasket inside of the other hasn't leaked in two years.
Re: any sure fixes on leaky brake master cyl. lid? [Re: stateroadhog] #1428021
04/30/13 05:16 PM
04/30/13 05:16 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I used a very thin layer of the gray "Form a Gasket". It hasn't leaked a drop since.
Re: any sure fixes on leaky brake master cyl. lid? [Re: burdar] #1428022
04/30/13 09:26 PM
04/30/13 09:26 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Yup. I have done this on several vehicles and it has worked great.
Stan
Re: any sure fixes on leaky brake master cyl. lid? [Re: HemiStan] #1428023
04/30/13 10:19 PM
04/30/13 10:19 PM
middleburg,fl
barryv Offline
barryv  Offline
middleburg,fl
I just had the same problem . I tried two different similar covers and it still leaked,bought new master cylinder and no more leak
Re: any sure fixes on leaky brake master cyl. lid? [Re: RonaldV] #1428024
05/01/13 06:13 PM
05/01/13 06:13 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I found that if I don't have my cover perfectly centered (front-back, left-right) that the fluid tends to weep.
When it's centered, no leaks. The lid will likely want to readjust on you when you slide the wire bail over the top so you have to make sure you don't loose the centered position when securing.
If you have more than one lid, you may try and find the one that has the least amount of slop.
Re: any sure fixes on leaky brake master cyl. lid? [Re: cruzin] #1428025
05/01/13 10:18 PM
05/01/13 10:18 PM
IN
ahy Offline
ahy  Offline
IN
I had a new MC that was a leaker and found the tension on the bail was less on one end. I adjusted (bent) it and leak fixed.
Re: any sure fixes on leaky brake master cyl. lid? [Re: ahy] #1428026
05/01/13 11:34 PM
05/01/13 11:34 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Had repeated problems with my current master cylinder. Replaced gasket, tried two gaskets, and filed sealing surface to no avail. Decided to bend (tighten) the bail in my vice and reinstall. Has not leaked since, going on about two years.
Ron
Re: any sure fixes on leaky brake master cyl. lid? [Re: stateroadhog] #1428027
05/02/13 07:18 AM
05/02/13 07:18 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
worked for me too
