904 low gear question...
#1427554
04/29/13 03:51 PM
04/29/13 03:51 PM
Posts: 311 Colorado Springs, Colorado
Dartthunder340
Is there a way to tell if my 904 already has the low 1st gear in it? It is already installed and I am wondering what it has, thanks.
Better get inside Ma. Looks like a storm's comin'.
Re: 904 low gear question...
[Re: Dartthunder340]
#1427555
04/29/13 03:55 PM
04/29/13 03:55 PM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
I don't know of way without taking it apart. Once you get the pump out and the front and rear clutches you remove the snap ring on the output shaft and thrust washer, then pull the planetary set out of the shell and pull the shell. If the sun gear in the shell is larger in front than in the rear then you have the low gear set. If the sun gears are both the same size than you have the standard set. Only way I know to tell.
[Re: 82ramIndy493]
#1427557
04/30/13 04:25 PM
04/30/13 04:25 PM
Posts: 25,995 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Nothing prior to '80 had the low gearset, by '82 they all had it.
Since this is in the Race forum the OP probably wants to know if the low gearset was installed at the time of build.
[Re: John_Kunkel]
#1427558
04/30/13 04:59 PM
04/30/13 04:59 PM
Guitar Jones
That's what I was thinking also, no way to know. The core case could have came from anything.
[Re: Guitar Jones]
#1427559
04/30/13 10:50 PM
04/30/13 10:50 PM
Dartthunder340
Thanks for your replies everyone and I do want to know if it was installed during the build. I guess really there is no way to know without tearing it down. No biggie I am trying to figure out some things on this new motor and that had come up in discussion.
