Brake guys - need some advice #1427414
04/29/13 10:53 AM
04/29/13 10:53 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
hey guys Im upgrading to Wilwood 4 piston front & rears disc brakes on my A body and was looking for advice on the following:
i. Who is using this setup on a street car? Mine has the OEM
style dust seal caliper that clear 15" wheels.
ii. What disc/disc MC bore size did ya 'all use and how did it
work pedal wise and braking wise ?
iii. My brake pedal has two holes for the MC pushrod, I'm
guessing one give 6:1 for man brakes and the other is for
boosted brakes, which is what the car had ex factory (they
DID come unboosted as well)
iv. I have a prop valve - in which line should I mount it and
where?
Ive seen so much conflicting info on here and other sites that its a joke.
Any tips /advice would be much appreciated thanks fellas...
Re: Brake guys - need some advice [Re: LAD 524] #1427415
04/29/13 11:33 AM
04/29/13 11:33 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
street car? autocross car? road course only car? combination car?
what kind of prop valve? stock? put it in the stock location.
manualy adjustable by turning the knob? put it in the line to the rear brakes, if you want you can set it up to be right next to the driver's seat with the knob sticking up inside the car so you can adjust it on course if needed.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Brake guys - need some advice [Re: amxautox] #1427416
04/29/13 11:34 AM
04/29/13 11:34 AM
amxautox Offline
amxautox  Offline
read all the other threads on brakes and components, must be around 5 other threads.
Tom
author unknown
Re: Brake guys - need some advice [Re: amxautox] #1427417
04/29/13 11:55 AM
04/29/13 11:55 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
At least...Talk to Wilwood, it's their brakes.
Re: Brake guys - need some advice [Re: amxautox] #1427418
04/29/13 12:09 PM
04/29/13 12:09 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Its a street/strip car.
Aftermarket prop valve with man adjustable knob. Ive read a lot of the other threads and whilst some are OK, many are conflicting. So Im wondering if anyone is running this combo and how it is working for them?
Thanx
Re: Brake guys - need some advice [Re: LAD 524] #1427419
04/29/13 12:16 PM
04/29/13 12:16 PM
amxautox Offline
amxautox  Offline
drag race car---what are the drag racers using?
Tom
author unknown
Re: Brake guys - need some advice [Re: amxautox] #1427420
04/29/13 09:35 PM
04/29/13 09:35 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Street/strip...where id I say drag race only ?
If anyone is using this combo, I d love to hear your real world exp and parts used, especially the MC selection.
Ive seen Wilwood give conflicting info as well.
thanks
Re: Brake guys - need some advice [Re: LAD 524] #1427421
06/14/13 02:09 PM
06/14/13 02:09 PM
Pittsburgh, PA
bobdog106 Offline
bobdog106  Offline
Pittsburgh, PA
I switched from drums to Wilwood,along with manual MC. I tried 1 1/16 bore and peddle was too hard and not enough pressure. I called Dr. Diff and he sent me out a 15/16 with adaptor. It works much better with less effort. The line locks even locked the front tires, where as before it pushed through before.
Re: Brake guys - need some advice [Re: LAD 524] #1427422
06/14/13 02:14 PM
06/14/13 02:14 PM
amxautox Offline
amxautox  Offline
thanks
I didn't say 'drag race only'. I said "what are the drag racers using?" as 'strip' means 'drag racing', 'course' means 'road course or autocross', pay attention.
Tom
author unknown
Re: Brake guys - need some advice [Re: LAD 524] #1427423
06/14/13 08:39 PM
06/14/13 08:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Go here: http://www.3gduster.com/brakes.html
Open the brake math spreadsheet. Crunch your numbers. Ignore my typos.
- Stu Harmon
