A/C Pulley #1427364
04/29/13 09:22 AM
04/29/13 09:22 AM
Jax, Florida
1976duster Offline OP
Jax, Florida
What are the different size pulleys for a/c and non a/c?
Re: A/C Pulley [Re: 1976duster] #1427365
04/29/13 10:32 AM
04/29/13 10:32 AM
scratchnfotraction Offline
a/c WP pulley is 4-5 inch diameter
non a/c WP pulley is 6-7 inch diameter
the a/c pulley spins the wp impeller faster so a 6 vane is used.
the larger non a/c pulley spins the wp slower so a 8 vane pump is used
both should flow the same X amount of water at idle.
it is possiable for the 8 vane pump to cavitate at high rpm when used with the smaller/faster a/c pulley.
Re: A/C Pulley [Re: scratchnfotraction] #1427366
04/29/13 06:55 PM
04/29/13 06:55 PM
Jax, Florida
Jax, Florida
Thanks for the reply!
Now do you know where I can get a a/c pulley at?
Re: A/C Pulley [Re: 1976duster] #1427367
04/29/13 11:21 PM
04/29/13 11:21 PM
IN
ahy Offline
ahy  Offline
IN
Bouchillon has nice steel repops. They were also helpful in getting my system set up and matched.
http://www.bpeusa.com/
Re: A/C Pulley [Re: ahy] #1427368
04/30/13 09:19 AM
04/30/13 09:19 AM
I think 440source may have pulleys also.
Re: A/C Pulley [Re: scratchnfotraction] #1427369
04/30/13 12:41 PM
04/30/13 12:41 PM
Jax, Florida
Jax, Florida
Neither one carry what I need. They carry the pulley for non a/c, which is what I have.
Re: A/C Pulley [Re: 1976duster] #1427370
04/30/13 01:53 PM
04/30/13 01:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have a couple .
