1970 LA plant Barracudas #1427155
04/28/13 09:30 PM
04/28/13 09:30 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Numbers Dudes....was there E body production at the LA plant in 1970, specifically the Barracuda line?, and if so would a 70 440/6 equipped Cuda have either the turn down dual tips, or "standard" thru the rear valance chrome tips?
Mike
Re: 1970 LA plant Barracudas [Re: DAYCLONA] #1427156
04/28/13 10:14 PM
04/28/13 10:14 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It depends on the destination of the car not that it was built in LA.
If the car was going to be sold in CA it was coded for noise reduction do it would have no tips.
If an LA built car was destined for Texas it would have tips like any other non-CA sixpack or hemi e-body.
Re: 1970 LA plant Barracudas [Re: DAYCLONA] #1427157
04/28/13 10:22 PM
04/28/13 10:22 PM
Kirkland, Washington
Pacnorthcuda Offline
My 383 70 was an LA build. Normal thru the valance tipped exhaust
Re: 1970 LA plant Barracudas [Re: Pacnorthcuda] #1427158
04/28/13 10:36 PM
04/28/13 10:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Only certain motor combinations mandated turn downs for cars sold in California in 1970 and 1971. No matter which plant they were built in.
For instance 70 Hemi E-bodies, built in Hamtramk of course, that were sold in California had turn downs as part of thier Noise Reduction package.
I believe for some cars/years the Noise Reduction package was more than just tips?
Re: 1970 LA plant Barracudas [Re: Morty426] #1427159
04/29/13 10:10 AM
04/29/13 10:10 AM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
OK...so if that's the case, what I'm looking to do is a "clone" recreation, but in OEM configuration, the car will be black in color, and I wanted to do a stock OEM undercarriage, but wanted to avoid doing it as a Hamtramck assembled car with a grey undercarriage, and preferred the black primed undercarriage and minimal undercoating....
Thanks guys for the responses
Re: 1970 LA plant Barracudas [Re: DAYCLONA] #1427160
04/29/13 10:52 PM
04/29/13 10:52 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That's correct. There are also some other tid bits that got done different in LA.
I assume you are building a sixpack car. A 440 four barrel E body out of LA would have had tips
Re: 1970 LA plant Barracudas [Re: Morty426] #1427161
04/29/13 10:59 PM
04/29/13 10:59 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Correct...I haven't decided on a tranny yet, Auto? or 4spd?....leaning towards 4spd
Mike
