Busted studs in hood for air grabber #1426986
04/28/13 07:55 PM
04/28/13 07:55 PM
Delta BC, Canada
Baller Offline OP
Baller  Offline OP
Delta BC, Canada
Pulled out the air box on my'70 GTX and broke some of the studs off from the hood. I'm not too sure as to how the studs go in as my FSM has the '69 diagram. I'm thinking that I may need to drill out the spot welds to separate the plate from the hood. If anyone has an idea as to how to replace these studs, please chime in. Thanks.
1970 GTX, work in progress...
Re: Busted studs in hood for air grabber [Re: Baller] #1426987
04/30/13 12:15 AM
04/30/13 12:15 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I broke a couple off mine too. I ground down the remaining portion and then mig welded a new stud on. A little tricky. I tried to minimise the heat used and had to do quite a bit of detail grinding and filing to dress down the weld.
Re: Busted studs in hood for air grabber [Re: 469runner] #1426988
04/30/13 12:46 AM
04/30/13 12:46 AM
Delta BC, Canada
Baller Offline OP
Baller  Offline OP
Delta BC, Canada
I think that may be the best way to do it. Thanks for the tip.
