Narrowing a Dana 60....
#1426509
04/28/13 02:30 AM
04/28/13 02:30 AM
Posts: 10,160 A Red State
SNK-EYZ
A Red State
I probably already know the answer but I got a Dana 60 parts question. I dropped off my Dana 60 housing to have it narrowed and after checking it out the guy building it called to let me know that one of the bearing races has spun in the housing. Is there any way to fix it? Does anyone make an oversized bearing and race? Is it just junk and I need to find another housing?
Re: Narrowing a Dana 60....
[Re: RobX4406]
#1426511
04/28/13 02:41 AM
04/28/13 02:41 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I assume you're talking the carrier races? I have no answers for you other than try one of the suppliers like Randy's ring and pinion and see what the say.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: SNK-EYZ]
#1426513
04/28/13 02:52 AM
04/28/13 02:52 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Just call Strange and get a housing in the width you need already done. If your housing is hogged out the price to fix RIGHT would not be cheap.
Mopar to the bone!!!
[Re: blue_stocker]
#1426515
04/28/13 10:51 AM
04/28/13 10:51 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
The Dana that I narrowed had a spun housing. The 4x4 shop that jigged it had to machine the housing to fit their jig and the shop that assembled the rear claimed they had to re-machine the same area. By that time I was so far into it, there was no turning back. Still it was less than a new Strange unit. Seems to be a common problem.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1426516
04/28/13 12:28 PM
04/28/13 12:28 PM
SNK-EYZ
A Red State
Thanks for the replies! I've got another housing but it's one of the 2-3/4 inch axle tube ones and I was trying to use the 3 inch axle tube one I had. I've been collecting parts for years. It seemed silly to buy a complete new one from Strange since I already have a brand new set of Richmond 4.10 gear, a new 35 spline power lock and depending on the width a set of 35 spline axles. I guess I'll have to decide what I'm doing now.
[Re: SNK-EYZ]
#1426517
04/28/13 12:33 PM
04/28/13 12:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Need to know which bearing... but if its a axle he should be putting on new ends anyways EDIT sorry I see you just posted its the center
[Re: DoctorDiff]
#1426522
04/29/13 02:42 AM
04/29/13 02:42 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Any good rearend shop should have a tool to machine the carrier saddles, as this is a common problem. I bought mine over 15 years ago.
If the stock caps are too far gone, billet steel versions are available for $100 each, with bolts.
BTW, this is proof you need to pre-load the carrier bearings. A properly assembled differential with new bearings will not "turn easily".
Everybody always tells me my case spreader was a waste of money... Here's to doing it right.
