Chrysler Marine BB oil pump cover #1426322
04/27/13 03:21 PM
04/27/13 03:21 PM
South Coast of Oregon
dweller Offline OP
dweller  Offline OP
Not sure if this is the right forum for this, please move if needed. I just wanted to post up some pictures of the neat Chrysler Marine oil pump cover that came OEM on marine 440s. They are plumbed so that oil is routed through a cooler before going to the block galleys. The stock coolers were copper tube in shell units that were cooled by the recirc antifreeze system. Perhaps this pump cover might have an automotive application for guys wanting an oil cooler...
Re: Chrysler Marine BB oil pump cover [Re: dweller] #1426323
04/27/13 03:22 PM
04/27/13 03:22 PM
dweller Offline OP
dweller  Offline OP
Here's another view...
Re: Chrysler Marine BB oil pump cover [Re: dweller] #1426324
04/27/13 05:27 PM
04/27/13 05:27 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I have the same cover on my boat with hoses going to the oil cooler. Mine doesn't have a closed system with antifreeze, it uses raw water and a twin impellor Sherwood pump. It also has a cooler for the Paragon trans fluid.
Re: Chrysler Marine BB oil pump cover [Re: B5 Bee] #1426325
04/27/13 08:25 PM
04/27/13 08:25 PM
dweller Offline OP
dweller  Offline OP
Paragon trans? Most of the Chrysler Marine engine packages included the Borg Warner "Velvet Drive" which is essentially an auto trans with a pump and one forward and one reverse gear. What is the Paragon?
Re: Chrysler Marine BB oil pump cover [Re: dweller] #1426326
04/27/13 08:36 PM
04/27/13 08:36 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I had one of those too...along with the cast aluminum oil pan, and cast iron timing cover off a marine 440 I had.
Re: Chrysler Marine BB oil pump cover [Re: dweller] #1426327
04/27/13 09:26 PM
04/27/13 09:26 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
It's not uncommon to find PL or PLV series Paragon transmissions behind Chrysler Marine 440's. Borg Warner V-D's seems to be most common with 318 Marines.
Re: Chrysler Marine BB oil pump cover [Re: dweller] #1426328
04/28/13 10:04 AM
04/28/13 10:04 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I haven't a freekin clue wth you guys are talking about..
