NOS AVS carburetors #1426087
04/27/13 05:37 AM
04/27/13 05:37 AM
alaska
69 mayflower Offline OP
alaska
I've got a couple of Nos AVS carburetors that are still in their original boxes, clean and in perfect condition. Is there any reason I shouldn't be able to just bolt them up and run em ? I haven't decided which one I'll be using, but since they are 40+ years old, I'm just curious if anyone out there has bolted an old Nos one up and had it work out. I'm thinking it should be fine. Opinions?
1969 Plymouth Sport Satellite 383 1990 Dodge W150 plowtruck 318 2012 Dodge Ram 1500 4WD 5.7 HEMI 2012 Dodge Challenger R/T Classic Blackberry Pearl 5.7 HEMI MOPAR- WHAT ALL OTHER CARS WANT TO BE WHEN THEY GROW UP-
Re: NOS AVS carburetors [Re: 69 mayflower] #1426088
04/27/13 10:55 AM
04/27/13 10:55 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
They should run fine. Only issue I can imagine is that the accelerator pump might have dried out since it is leather. You might be able to rejuvenate it with a soak in some ATF. Only a quick disassembly would confirm that.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: NOS AVS carburetors [Re: herkamer] #1426089
04/27/13 06:23 PM
04/27/13 06:23 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Agreed, should be fine but if not you won't know without a test run or a tear down. The acc pump or the needle/seats being dry or sticky would be the trouble areas in most cases.
