72 Cuda manual to power steering swap #1425804
04/26/13 04:26 PM
04/26/13 04:26 PM
Essex, Ont., Canada
Fishmarket Offline OP
Essex, Ont., Canada
I have most everything for the swap, my question lies with the column. Can I modify the original 4 speed, manual column (i am a machinist), or swap a shaft in from an old power steering column, or do I need an entire power steering column?
Thx
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: 72 Cuda manual to power steering swap [Re: Fishmarket] #1425805
04/26/13 06:10 PM
04/26/13 06:10 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
The power steering shaft is shorter by a few inches. Other than that the columns are the same. If you have the ability you could modify the one you have. You will also need the coupler as the power box has a smaller diameter input shaft.
