Re: Axle upgrades for 78' 440 Ramcharger
[Re: 76dodgeboy]
#1424604
04/29/13 01:00 PM
04/29/13 01:00 PM
Posts: 364 Houston, Texas
Slant6pak
Houston, Texas
I can't find anything locally...
Which is part of the problem. Seems everytime I see axles for sale they are up in the rust belt.
I have yet to find a junkyard in Houston that has any old Dodge trucks left. Its been over 2 years since I've seen a 72-80 in a yard.
2016 Challenger Scat Pack Shaker ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) 1000 ci Brass Era Speedster project
[Re: Slant6pak]
#1424605
04/29/13 02:00 PM
04/29/13 02:00 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
You need to think outside the box...see my post above about the Chevrolet/GMC axles. My friend Bill was not a great fabricator, but he could bolt together parts and if I recall corectly the Chev/GMC driveline swap was nearly a bolt-in deal...the truck won't know what it is using for axles
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Slant6pak]
#1424606
04/29/13 07:05 PM
04/29/13 07:05 PM
Posts: 5,965 Greenville, PA
redraptor
Greenville, PA
That's funny cuz' I can't find any rust free body parts locally. The ones I see online are in TEXAS! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: redraptor]
#1424607
04/29/13 07:24 PM
04/29/13 07:24 PM
Slant6pak
Houston, Texas
Nah none of that down here.
At least none that I can find in yards. 72-80 trucks down here are rusted out too, just not as bad.
My RC is swiss cheese below the bodyside molding. Probably could find a less rusty truck... but the patch panels are available and this truck has sentimental value to me.
[Re: Slant6pak]
#1424608
05/01/13 08:34 PM
05/01/13 08:34 PM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
Chevy axles are not bolt in....the spring pad width on the dana 60 front is at least an inch different. The two times I put 14 bolts in the rear of my Dodges, I had to cut the spring perches off and re-weld them. That is easy but the front end is not an easy deal. The Dodge springs are wider then the pads on a Chevy, and the passenger side is cast into the center section, so its not a cut/weld deal. Have cash in hand and be patient. Watch 1stgen.org classifieds, Pirate4x4 classifieds, and other cites like that for dana 60 fronts from Dodges.
Its not impossible, I just don't want the original poster to buy axles from a Chevy and they will swap in easily.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: 76dodgeboy]
#1424610
05/01/13 11:02 PM
05/01/13 11:02 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
use a dana 60 front open knuckle,with good spicer u-joints,and a gm 14 bolt rear.weld the snot out of the spiders to form a "Lincoln lock" and you will have a set of axles that will take a while to break...also use a 205 transfer. I ran a stout big block,and new TSL 44" swampers,and added hydro steering,and a ARB airlocker in the front.. ![](/ubbthreads/images/graemlins/punkrocka.gif) note don't waste you time on any junk d44 fronts,OR any d60 rears. they snap like twigs! the 60 rears have very small axle shafts,and are not like our car units.if your not breaking these,you don't have any power..at all,lol.
[Re: imfixinmopars426]
#1424611
05/01/13 11:24 PM
05/01/13 11:24 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Double check your brakes, IIRC the D44 and D44HD both use the same caliper, and pad.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
#1424612
05/01/13 11:53 PM
05/01/13 11:53 PM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I ran 35 spline on my dana 60 with no issues. Ran 44 cut boggers or 14 paddle bigger diggers on 36 inch casings at about 1200 HP.
[Re: MMiller]
#1424613
05/09/13 06:50 AM
05/09/13 06:50 AM
Posts: 2,141 junction city oregon
viperblue72
Michael
A chevy front end does bolt into a dodge. There is a bit of width difference, but it is close enough, especially with lift springs that alot of people just bolt them in and it works just fine.
[Re: viperblue72]
#1424614
05/12/13 03:18 PM
05/12/13 03:18 PM
Slant6pak
Houston, Texas
Can somebody post a pic of the 75-79 Dodge D60 full time front axle?
I know these have drive flanges and are bolt in but I have no idea what this setup actually looks like....
Will the assembly have an part/casting numbers to identify it?
Dimensions?
I'm trying to get in contact with a local guy that is supposed to have a pile of Dana 60 fronts... I want to make darn sure I'm getting what I want before paying his price.
