The 340 just keeps making more power! Best slips yet #1424511
04/23/13 10:31 PM
04/23/13 10:31 PM
Redding,CA USA
440charger500 Offline OP
Redding,CA USA
So first couple passes out this year with new dart and 340 have been good. Started in 11.80's @ 112mph. From there we went up 2 jet sizes and and dropped plugs heat range from RC12YC to RC9YC. 340 responded well and ran a tenth faster. So last weekend we set timing up from 35 degrees to 37 and installed the caltracs mono leafs (caltrac bars already installed). First pass out was a 11.71 @ 114mph and then I got these 2 timeslips.
Re: The 340 just keeps making more power! Best slips yet [Re: 440charger500] #1424512
04/23/13 10:37 PM
04/23/13 10:37 PM
Redding,CA USA
Redding,CA USA
Yellow slip doesnt have all increments because an altered took out the sensors before my pass. Bummer cause Id like to see the all numbers. Heres the 340! Enjoy
Re: The 340 just keeps making more power! Best slips yet [Re: 440charger500] #1424513
04/23/13 11:07 PM
04/23/13 11:07 PM
Plant city fl
70Dart499 Offline
70Dart499  Offline
Plant city fl
Mind sharing your combo? I've got a 340 coming together right now, and I'm curious to hear what your combo is.
1970 Dart Drag Car
Re: The 340 just keeps making more power! Best slips yet [Re: 440charger500] #1424514
04/23/13 11:18 PM
04/23/13 11:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats good... but dont stop there.. if you jetted up
2 sizes and it picked up then go 2 more till your MPH
starts to drop then back up 1 size... then after you
find the sweet spot then advance the timing some but
watch your plugs..... good job
Re: The 340 just keeps making more power! Best slips yet [Re: MR_P_BODY] #1424515
04/23/13 11:25 PM
04/23/13 11:25 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Not too shabby, have you tried 34° timing yet? All our SB's love it. Making a timing and spring change together you really can't credit either. Just my .02
Re: The 340 just keeps making more power! Best slips yet [Re: SpareParts] #1424516
04/23/13 11:34 PM
04/23/13 11:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would have said 34* or so also but with my last
SB it liked 39*... we didnt go higher.. I said 39*
was far enough... so test, test and test... dont ever
think that should be it...........JMO
Re: The 340 just keeps making more power! Best slips yet [Re: SpareParts] #1424517
04/23/13 11:42 PM
04/23/13 11:42 PM
Redding,CA USA
Redding,CA USA
Timing started @ 35. I dont think the mono leafs changed et much because 60fts stayed the same. I was looking more at the mph for the hp increase. 112mph then 115 now, same DA @ 1000 ft.
Re: The 340 just keeps making more power! Best slips yet [Re: 440charger500] #1424518
04/24/13 07:57 AM
04/24/13 07:57 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Good deal! I started out with a 71 scamp that had a mild 340 in it, ran 11.70s at 115 at 3200 pounds, lots of fun and very streetable!
Re: The 340 just keeps making more power! Best slips yet [Re: ProSport] #1424519
04/24/13 12:20 PM
04/24/13 12:20 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Always a good feeling to go faster every time out. Ron
Re: The 340 just keeps making more power! Best slips yet [Re: 70Dart499] #1424520
04/24/13 06:24 PM
04/24/13 06:24 PM
Redding,CA USA
Redding,CA USA
340 .030 trw slugs fly cut for closed chamber heads
ported eddys 62cc with 10.34to1 comp
Lunati voodoo solid
RPM Intake with 1" wilson open spacer
750 HP Carb
headman Hustlers
3200lb 67 Dart
Re: The 340 just keeps making more power! Best slips yet [Re: 440charger500] #1424521
04/24/13 09:18 PM
04/24/13 09:18 PM
Plant city fl
70Dart499 Offline
70Dart499  Offline
Plant city fl
Thanks, that's very similar to my combo good luck with it.
1970 Dart Drag Car
Re: The 340 just keeps making more power! Best slips yet [Re: 440charger500] #1424522
04/25/13 03:17 AM
04/25/13 03:17 AM
Which track was that at?
Re: The 340 just keeps making more power! Best slips yet [Re: Cab_Burge] #1424523
04/25/13 04:43 PM
04/25/13 04:43 PM
Redding,CA USA
Redding,CA USA
Redding Dragstrip. Oldest track around
Re: The 340 just keeps making more power! Best slips yet [Re: 440charger500] #1424524
04/25/13 07:05 PM
04/25/13 07:05 PM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
Sounds like you've got it dialed in pretty well.
What converter, gear, tires?
Experiment with squirters and acc pump cams. Tune for best 60 ft, then jet for MPH
Paul
Re: The 340 just keeps making more power! Best slips yet [Re: 74DusterP457] #1424525
04/26/13 12:50 AM
04/26/13 12:50 AM
Redding,CA USA
Redding,CA USA
its got a spec-rite 4000 converter with 4.56's out back. I think the squirters are pretty good put 37's in & have pink pump cams. I think that I really need to play around with the caltracs & QA1's, I would like my 60fts in the upper 1.50's.
Re: The 340 just keeps making more power! Best slips yet [Re: 440charger500] #1424526
04/26/13 01:00 AM
04/26/13 01:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Actually if the MPH went up you are making more power
so the 60' should have dropped some if it was hooking
up right... like I said before.. keep going fatter
till your MPH drops
