727B ext housing output shaft seal removal/install tips #142265
10/27/08 11:55 AM
10/27/08 11:55 AM
NoVa
E
ebodyseast Offline OP
E
NoVa
Special tools for removal/installation of the trans rear shaft seal are pictured in the FSM - what other more common tools may be substituted in their place - and does anyone have any good tips to ease in the re-assembly?
Re: 727B ext housing output shaft seal removal/install tips [Re: ebodyseast] #142266
10/27/08 12:00 PM
10/27/08 12:00 PM
Kirkland, Washington
Pacnorthcuda Offline
Tailshaft seal?
This is an easy seal to R&R. There is a metal lip around the circumference, just insert a small screwdriver and pry in few locations around it. It'll come out.
Last time I put one in I used a short length of exhaust pipe that had the same diameter as the lip. Gently drive it in. You could also use a wood block.
He's BAAAAACK......
Re: 727B ext housing output shaft seal removal/install tips [Re: Pacnorthcuda] #142267
10/27/08 06:24 PM
10/27/08 06:24 PM
NoVa
E
E
NoVa
I'm back baby!! (Thanks Tom!)
Great info Greg - screwdrivers & wood I do have, peace brother...
