4.15 B engine stoker crank/chevy rods #1422493
04/20/13 02:19 PM
04/20/13 02:19 PM
PA
moparacer Offline OP
PA
Anyone know if there is a source for a 4.15 stroke, 6 bolt, 400 main stroker crank with chevy 2.20 rod journals?
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 4.15 B engine stoker crank/chevy rods [Re: moparacer] #1422494
04/20/13 02:23 PM
04/20/13 02:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Callies will make you up one... I bought a 440 main
2.2 4.15 from them... they will turn the mains... call them
Re: 4.15 B engine stoker crank/chevy rods [Re: MR_P_BODY] #1422495
04/20/13 02:56 PM
04/20/13 02:56 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I would give either Todd @ Competition Wedge or Dan @ Performance only or Bob @ Bob George Racing a call. All members and you can't go wrong with any of them.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 4.15 B engine stoker crank/chevy rods [Re: pittsburghracer] #1422496
04/20/13 03:00 PM
04/20/13 03:00 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
You could be in luck.
Mancini overstock sale:
http://chucker54.stores.yahoo.net/384st6bo10ea.html
Re: 4.15 B engine stoker crank/chevy rods [Re: AAR-B4] #1422497
04/20/13 03:04 PM
04/20/13 03:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
He would still need to have it cut for chevy rods
Re: 4.15 B engine stoker crank/chevy rods [Re: MR_P_BODY] #1422498
04/20/13 03:17 PM
04/20/13 03:17 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
It would be worth a call. Eagle has the rods for this combo (6.760) in both 2.375 and 2.200.
Re: 4.15 B engine stoker crank/chevy rods [Re: moparacer] #1422499
04/20/13 03:22 PM
04/20/13 03:22 PM
I buy the 4.150 stroke RB/Hemi cranks and have the rods offset ground down to 4.25 or 4.300 stroke with the BB Chevy rod journal sizes and have the mains and counterweights cut down at the same time
Re: 4.15 B engine stoker crank/chevy rods [Re: Cab_Burge] #1422500
04/20/13 03:33 PM
04/20/13 03:33 PM
Nv
Bill Koski Offline
Bill Koski  Offline
Nv
Ohio Crankshaft!
Re: 4.15 B engine stoker crank/chevy rods [Re: Bill Koski] #1422501
04/20/13 06:47 PM
04/20/13 06:47 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
K1 makes one. 383-4150TC6F
Re: 4.15 B engine stoker crank/chevy rods [Re: supercomp] #1422502
04/20/13 11:01 PM
04/20/13 11:01 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
That is correct Supercomp. That is the low deck 4150 X 2.200 crank. I just checked on one of these last week.
The Eagle dont have 2.200, nor do the RPMS, but they do both make a 4.150 low deck, just not 2.200. The 6 bolt stuff is a little tougher to get usually.
RIP Monte Smith
Re: 4.15 B engine stoker crank/chevy rods [Re: supercomp] #1422503
04/21/13 12:21 AM
04/21/13 12:21 AM
PA
PA
Shows that its 8 bolt.
Thanks for all the options. Will start calling around Monday and checking.
I might get stuck just ordering that .10 .10 crank off mancini and turning the rod journals down.
Re: 4.15 B engine stoker crank/chevy rods [Re: moparacer] #1422504
04/21/13 11:02 AM
04/21/13 11:02 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Must have changed it. We bought one last year and it was a 6 bolt. Better call. Same part number.
Re: 4.15 B engine stoker crank/chevy rods [Re: supercomp] #1422505
04/21/13 12:14 PM
04/21/13 12:14 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Yeah, the 6 in the PN used to correspond to the number of holes in the flange.
Re: 4.15 B engine stoker crank/chevy rods [Re: moparacer] #1422506
04/21/13 02:46 PM
04/21/13 02:46 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I am pretty sure Molnar Technologies makes a 6 bolt 4.15 crank. contact http://www.4secondsflat.com/ and ask for a quote, you won't believe the price.
I just got a 4.25 stroke and it is dead on spec.
Joe
Without Data, you’re just another guy with an opinion.
Re: 4.15 B engine stoker crank/chevy rods [Re: 64Post] #1422507
04/21/13 05:20 PM
04/21/13 05:20 PM
Syracuse,NY
Syracuse,NY
Actually not true. The 6 is the number of counterweights.
Here is how that part number breaks down:
383 is obvious
4150 stroke
J is main journal ( Chysler Hemi)
C is 2.200 rods
6 is counterweights
F is forged crank
What K1 and Molnar ( Molnar used to BE K1) did, was use the prefix " 426" for any BBM crank with 8 bolt flange, and " 440" for any crank that was 6 bolt flange.Since Wiseco bought out K1, maybe they made some changes in that regard.
383-4150TC6F used to be the old K1 part number. T standing for 383/400 BBM, more so for counterweight dimensions.
I will try to get ahold of Molnar today and get an answer. I was pretty sure the old K1 383/400 WERE 6 bolt. Perhaps that has changed as mentioned. I have been trying to get a few of these guys to get more 6 bolt cranks, as many people have exisiting 6 bolt parts, and to be honest, there is no big gain in the 8 bolt style for most applications anyhow. It was from the Hemis years ago, and everyone simply stuck with it because they felt the 8 bolt Hemi pattern was superior. I have still yet so see anyone tear 6 bolt outta the crank flange,...
RIP Monte Smith
Re: 4.15 B engine stoker crank/chevy rods [Re: CompWedgeEngines] #1422508
04/21/13 09:21 PM
04/21/13 09:21 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
383 is obvious
4150 stroke
C is 2.200 rods
6 is counterweights
F is forged crank
Well that's what I get for ASSuming...
Re: 4.15 B engine stoker crank/chevy rods [Re: 64Post] #1422509
04/22/13 01:41 PM
04/22/13 01:41 PM
Syracuse,NY
Syracuse,NY
Oh, dont worry 64, we ALL been there a time o r two!..
Molnar only has 8 bolt flange for that crank folks, no 6 bolt. I would much rather change the flexplate to 8 bolt than grind the 2.375 journals down. ( unless this is a stick car?)
RIP Monte Smith
Re: 4.15 B engine stoker crank/chevy rods [Re: CompWedgeEngines] #1422510
04/22/13 03:21 PM
04/22/13 03:21 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
How hard could it be to reprogram the CNC to do a 6-bolt flange?
