Re: Compatible leaf springs
[Re: lenogris]
#1422357
04/20/13 11:38 AM
04/20/13 11:38 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
There were several leaf packs that could have been used on your car. You can look in a '66 parts book to see which ones. Generally a spring that has been cycled excessively or overloaded is not really a good choice for continued use. If you do get used, then look 'em over for signs of failure, then load them up (stand on 'em is one way - but do hold on to something get on and off!) and measure the deflection. Then calculate the spring rate of each. If left and right are not the same - one or both is worn out. If they are OK, you can rebuild with new interleafs and bushings. This company has some information posted http://www.stengelbros.com/DodgeCarLeafSprings.htm the link was posted in this thread https://board.moparts.org/ubbthreads/showflat.php?Number=7193764which you may find some it helpful
[Re: lenogris]
#1422359
04/21/13 03:05 AM
04/21/13 03:05 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Drag racing would necessitate biased springs, if you want to drive it more, go with the same number of leafs on them and use cal tracks. ESPO or JR spring will ship them for a reasonable price. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
