'70 Challenger Seat Hinge Covers? (Paint) #1422116
04/19/13 03:04 PM
04/19/13 03:04 PM
California, USA
filmsurgeon Offline OP
California, USA
Looking for some help/advice on repainting the seat hinge covers. The previous owner spray painted the entire hinge cover white (including the release button). I know the release buttons were all black regardless of the interior color. I plan on stripping off the old paint first before respraying. The question I have is "how can I get the button black, and the hinge cover white without getting overspray on either?" I imagine I could: (1) mask off the cover; (2) spray the button black; (3) try and slip plastic over/around the button from the backside of the hinge cover; (4) spray the hinge cover white. I don't think that removal of the button is an option because it is "blind riveted" to the backside of the hinge cover. I know it could be removed by cutting off, or drilling out the blind rivets, but I don't know how it would/could be reattached. Any/all feedback is appreciated. Thanks.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422117
04/20/13 02:59 AM
04/20/13 02:59 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
First I'll tell ya, strip the old paint off that part, the grain is already buried, every coat of paint buries it more.. About half the hinge covers I've seen the button is no longer attached to the hinge cover & when it's installed you can't tell... so if you separate the button & don't reattach it the button will still look & work just fine...
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422118
04/21/13 07:44 PM
04/21/13 07:44 PM
California, USA
California, USA
Here are the seat hinge covers after multiple applications of paint remover/stripper, and using a scouring pad on the last two applications. Inner hinge covers appear to have been originally B5 Blue (remnants of original paint still remain in the tight corner areas). Outer seat hinge covers appear to have been originally Black (very little remnants of originally paint left). Help/advice is still needed on: "how to paint the button black, and the hinge cover white without getting overspray on either". Is there an option for removing the spring steel button plate (or the button itself) to make it easier to paint. Of course I'd need/want to reattach it somehow. Also, what paint is the best? Thanks.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422119
04/22/13 02:09 AM
04/22/13 02:09 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i repaired a loose button on mine but cant remember if i pop riveted or used a small screw, kind if think it was a small screw. anyway i redid my black ones with vinyl die soaked on a lint free rag and wiped it on, black spray paint buried the grain and so did spraying the dye.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: ademon] #1422120
04/25/13 03:14 AM
04/25/13 03:14 AM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
To reinstall the lever, go to the hardware store and get a push washer. It is a thin one way washer that will fit over the hole boss and hold it tight. You push the washer on and it won't come off because it is a tight fit.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: Steve340] #1422121
04/25/13 03:56 AM
04/25/13 03:56 AM
California, USA
California, USA
Thanks for the feedback, but I don't understand where you're saying to use the push nut (not called a push washer). The attached photo is the backside of the hinge cover. There are two swaged pins/posts (right) that hold the button's spring steel plate to the hinge cover. Then there's the button's own swaged pin/post (center) that holds it to the spring steel plate. The interesting thing about all this is that the rod /pin (left) is part of, or attached to the back side of the button, and the larger diameter collar attached to the bottom of the rod/pin is larger than the hole in the spring steel plate. I grabbed the rod/pin with a pair of pliers to try and see if it would unscrew from the button, but it will not.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422122
04/25/13 04:00 AM
04/25/13 04:00 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The push nut would attach to the screw hole shown to the far right in your photo..
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: 1_WILD_RT] #1422123
04/25/13 04:58 AM
04/25/13 04:58 AM
California, USA
California, USA
Ah ha!!
Interesting idea. I wonder though how well it would stay in place with repeated action of the button. I'll certainly consider it though as a possible solution. Thanks for the tip and the clarification.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422124
04/25/13 08:24 AM
04/25/13 08:24 AM
WI
RestoRick Offline
RestoRick  Offline
WI
I've always done these by spraying the whole thing with a coat of epoxy primer first, then spray the push button. After that, mask the button off with masking tape. The tape can be slipped under the edge as you press the button down.
No big deal...
The push retainer idea sounds interesting...
If one were intent on disassembling it, I think putting on the reading glasses and using a couple tiny screws to replace the original peened fastening would work well.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: RestoRick] #1422125
04/25/13 12:00 PM
04/25/13 12:00 PM
California, USA
California, USA
No big deal...
Thanks for clarifying (peened vs. swaged). I'm gonna try one first (removing the button at the two peened fasteners, paint, reassembly with small screw). I'm pretty confident I can do a good job of reattaching it. Found this not-so-good photo from a guy who was selling his covers. It does look like there are (3) screws used where the original peening was done.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422126
04/26/13 04:56 AM
04/26/13 04:56 AM
California, USA
California, USA
Removed the buttons tonight using a small fiber cut-off wheel on the dremel, and grinding down the two peened pins that hold the button's spring steel plate to the back-inside of the hinge cover. They're ready now for paint. To reattach them, I'll drill small holes (where the remainder of the pins are), and use small stainless tapping screws. I'll post photos after they're repainted/reassembled.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422127
04/27/13 07:54 PM
04/27/13 07:54 PM
California, USA
California, USA
Can anyone point me in the right direction for the correct white interior trim paint? The shade of white on my Legendary Interior's seat covers and my new Metro seat backs match each other. I'm looking to get that same shade of white to paint the seat hinge covers. Thanks.
I found the following:
The Metro paint says it's specially formulated to match their new interior panels, but it's expensive.
http://www.ebay.com/itm/360510184213
I see that Herb's Parts has its own line of interior paint, and it's reasonably priced. Herb's Color Chart indicates that "White" would be for 1969-76 Dodge, Plymouth, Chrysler, and that "Pearl White" would be for 1964-69.
http://www.herbsparts.com/proddetail.asp?prod=PAINT&cat=829
There is also:
SEM "Super White" (11440Z - FORD OEM - NOTE: This is really an off-white. - REVIEW: The super white is very close in shade to the Mopar pearl white of the sixties).
http://www.eastwood.com/super-white-interior-paint-aerosol-12-oz-net.html
SEM "White" (11438Z - FORD OEM - NOTE: This is really a bright white).
http://www.eastwood.com/white-interior-paint-aerosol-12-oz-net.html
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422128
04/29/13 05:54 AM
04/29/13 05:54 AM
California, USA
California, USA
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422129
04/30/13 06:59 PM
04/30/13 06:59 PM
California, USA
California, USA
Can anyone help on advice regarding the correct white interior paint?? Thanks.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422130
04/30/13 10:44 PM
04/30/13 10:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've used the SEM Super White on a 70 Challenger with white interior, it was a very good match... 808 Cuda tried it on his Cuda on my recommendation, you might contact him & see what he thought..
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: 1_WILD_RT] #1422131
05/03/13 02:03 AM
05/03/13 02:03 AM
California, USA
California, USA
Thanks. I'm gonna go with the SEM paint.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422132
05/04/13 01:22 PM
05/04/13 01:22 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
I use Super White on my Challenger which is less white than regular white. Don't ask me why they call it Super White when it is Off White in color. (as seen in the pictures above)
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422133
12/23/13 06:30 AM
12/23/13 06:30 AM
California, USA
California, USA
Need some help/advice please. See attached photos of the seat hinge cover I just painted using SEM "Super White" 15103. The color match is NOT good against my new Metro seat-backs. FYI - I will also need to paint both my original convertible rear panels, and armrest pads to match my new Metro door panels. Anyone have any suggestions on a paint that will match the Metro panels? I had previously mentioned Herb's "White" #1195 (reasonably priced), and Metro's interior white ($$EXPENSIVE$$, but Metro states their paint "has been specially formulated to be an exact match to the color and gloss of our new interior panel lines for the 1970-74 Cuda and Challengers"). Thanks.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: filmsurgeon] #1422134
12/23/13 05:49 PM
12/23/13 05:49 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Sorry to send you in a potentially different direction, but there has been a thread on here (Moparts) regarding 'suede' paint.
With a white interior, most metal parts would have been black suede(which is different than other colored interiors), however, wouldn't these parts have been suede painted?
I believe so, but I am only an expert sometimes.
Re: '70 Challenger Seat Hinge Covers? (Paint) [Re: RP's R/T's] #1422135
12/24/13 12:49 AM
12/24/13 12:49 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I just did mine and I did not remove the buttons. They are easy to paint and leave them on. They are easily masked off. I went to the paint store and bought a small can of W1 code white in a base coat paint and shot it. No clear on top and it comes out swede looking. Perfect match because that is what color it is per the factory service manual.
