B-body '69 8-3/4 rear in a '71 B-body
#1421106
04/16/13 11:37 PM
04/16/13 11:37 PM
Posts: 322 San Diego, CA, United States
Texas_Charger
Hello everyone, I have a '71 Charger with an 8 3/4 rear. It has a 489 case sure grip third member in it.
I picked up some 15x10 rims with only 3.5" of backspace that I want to put on it, and I have a lead on a rear end housing out of a '69 charger that is 3" narrower than the '71 housing that I have, so the rear tires wouldnt stick out like Joe Dirt.
My question is, besides relocating the spring perches, how difficult would it be to swap the two housings? I ran a search and didnt come up with anything, so I was hoping someone had done this before.
Thanks in advance!!
1971 Dodge Charger SE 470/727/3.91 Suregrip 2016 Dodge Challenger Hellcat, 6-speed 1980 Pontiac Trans Am, Y84, WS6 2002 Ram 2500 Cummins/6-speed/2WD/QC 1971 Ford F-350 Ranger
Re: B-body '69 8-3/4 rear in a '71 B-body
[Re: Texas_Charger]
#1421107
04/17/13 12:10 AM
04/17/13 12:10 AM
RapidRobert
I'd start with carefull measureing to see if 1.5" per side change plus the backspace change will clear the springs on the inside & the fender on the outside. ie a p225 tire the 225 is the sidewall bulge to sidewall bulge width in millimeters. divide 25.4 into that to get it in SAE (inches) & that dimention may help you in your clearance checks
[Re: RapidRobert]
#1421108
04/17/13 12:33 AM
04/17/13 12:33 AM
Texas_Charger
I'm confident that the wheel and tire will clear the springs and the fenders, I was wondering more along the lines of whether or not the brake drums and lines should interchange or if there are any other unforseeable complications I should think about.
Thanks!
[Re: Harley]
#1421112
04/17/13 02:21 PM
04/17/13 02:21 PM
Texas_Charger
looks sharp! that's a lot of rubber man.
Doc, if i can seal the deal in this rearend housing I'll be in touch with you for a spring relocator kit.
Thanks!
