Starter Relay keeps going out.... #1420840
04/16/13 02:34 PM
04/16/13 02:34 PM
Texas
E
ef8Cuda340 Offline OP
E
Texas
I've replaced about 4 starter relays on my 70 Challenger. Some new ones may be worthless because when I buy the replacement it works for a little bit, then it goes out again (even using different suppliers). I have used either a screw driver to make contact on both screws to start it or a remote starter cable, and then I can use the key thereafter, until it stops working again.
Should I be looking at another possible problem? All wiring seems to be intact, ignition switch seems to work fine, etc.
Any leads are appreciated.
Re: Starter Relay keeps going out.... [Re: ef8Cuda340] #1420841
04/16/13 02:49 PM
04/16/13 02:49 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes your neutral safety switch is giving you problems I bet. Mostly like needs adjustment by the shifter linkage.
Ground it at the relay to eliminate it for testing.
Re: Starter Relay keeps going out.... [Re: Challenger 1] #1420842
04/16/13 04:21 PM
04/16/13 04:21 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Agreed...
Re: Starter Relay keeps going out.... [Re: RSNOMO] #1420843
04/16/13 04:49 PM
04/16/13 04:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Next time it won't turn over try holding the key in the start position and move the shifter slowly from park to neutral. If it turns over then it is a NSS problem. Either a bad switch or shift linkage out of adjustment. Linkage doesn't need to be off much to keep the NSS from making contact correctly but it will still go into gear right.
Re: Starter Relay keeps going out.... [Re: stumpy] #1420844
04/17/13 11:40 AM
04/17/13 11:40 AM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
and keep your foot on the brake while doing that
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Starter Relay keeps going out.... [Re: aspenrt360] #1420845
04/18/13 03:00 PM
04/18/13 03:00 PM
Texas
E
E
Texas
I appreciate the feedback. This sounds like the most possible problem. I'll fix.
thanks,
