Re: How many here actually.....
[Re: loaderpro]
#1420815
04/17/13 12:08 AM
04/17/13 12:08 AM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
check them before each race torque to 125 lbs 5/8 stud.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: 440W8 Duster]
#1420816
04/17/13 01:46 AM
04/17/13 01:46 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I ALWAYS use a torque wrench! for wheel studs and anytime I can get one on any bolt or nut on the car.
[Re: max_maniac]
#1420817
04/17/13 07:00 AM
04/17/13 07:00 AM
Posts: 1,371 Tallmadge, Ohio
Butch
Tallmadge, Ohio
Every race day in the am and the trailer before every use. Cheap insurance and piece of mind.
'74 Duster 440 '04 Hemi Quad Cab Ram '06 Pacifica '78 MGB
[Re: MR_P_BODY]
#1420818
04/17/13 08:45 AM
04/17/13 08:45 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Nope... I have checked them a couple of times after I ran them on with the impact... give it a couple of rattles with the impact then checked... most of the times its within 5-10 ft lbs of the so called spec... close enough for me
thats how i do it.after 2,000 street miles,and numerous trips down the quarter checked em just because and they were still tighter than a fat girls sock.
[Re: dartman366]
#1420820
04/17/13 10:32 AM
04/17/13 10:32 AM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I found a loose lug nut on my Weld wheels using 1/2 inch studs years ago, not long after putting the wheels on. Some wheels use washers that deform when torqued, and keep deforming during use loosening up. I retorque often.
[Re: SpareParts]
#1420822
04/17/13 12:04 PM
04/17/13 12:04 PM
Triple Threat
Renton Washington
Part 2 of this question if I may: How many of you use anti seize or something else when putting them on?
[Re: Triple Threat]
#1420823
04/17/13 12:05 PM
04/17/13 12:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a couple drops of oil.. thats all
[Re: VernMotor]
#1420826
04/17/13 02:48 PM
04/17/13 02:48 PM
dartman366
Mt. Vernon, Ohio
Got an old but accurate Craftsman torque wrench as a spare,, guess it gets loaded in the trailer for track use, thanks guys.
[Re: dragram440]
#1420830
04/19/13 01:47 PM
04/19/13 01:47 PM
MR_P_BODY
It amazes me that I never seen any one at the track pull out a torque wrench after they had their wheels off... I have a big suspicion, theres a lot of BSing going on here
[Re: MR_P_BODY]
#1420831
04/19/13 02:37 PM
04/19/13 02:37 PM
Challenger 1
Cincinnati, Ohio
I had 6 guys helping me race, Scott did the tires. He took them off almost every run so we could work around the car. He also did the air, kept the tires covered, checked them with a torque wrench every run even if we didn't take the tires off. He also did the fuel and lot's of other stuff each round. We had a routine and stuck to it.
I have 2 torque wrenches in my tool tray another in our tire tool tray as there is a lot torquing going between rounds in TAD.
