Re: fender tag
[Re: kidmopar]
#1420414
04/15/13 08:08 PM
04/15/13 08:08 PM
Posts: 21,555 N.E. OHIO, USA
A12
N.E. OHIO, USA
Yes , Fender tag is body color ..........
and I believe it is bent in the upper left hand corner and the left screw is painted too (but the right hand screw is not painted)
Re: fender tag
[Re: RP's R/T's]
#1420417
04/23/13 02:08 AM
04/23/13 02:08 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
The factory screwed the fender tag with one screw initially (LH) and bent up the fender tag. After it was painted, the RH screw was added (RH screw is plated and would not have paint). So, there was a small amount of overspray on the backside, if you want it like the factory. I would say everyone else paints the backside so it doesn't rust.
Depends on the plant also ... ![](/ubbthreads/images/graemlins/fan.gif)
