727 locked up while in 1st ??? ***UPDATE***
#1420139
04/15/13 02:11 AM
04/15/13 02:11 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I replaced the stock valve body in my 727 with a Turbo-Action forward pattern manual LBA unit. I don't know much about tranny's, but followed the directions that came with the valve body. It's all back together now, and its locked up when in 1st. You can feel the converter working against it, as if you have the brake on. All other gears seem to work okay.
I'll call Paul @ Turbo Action tomorrow and I'm sure he'll know whats going on, but I thought I'd post here as well. Any thoughts? tranny guys, what do I have going on, here?
Re: 727 locked up while in 1st ???
[Re: StealthWedge67]
#1420140
04/15/13 10:23 AM
04/15/13 10:23 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Can you push the car while its in 1st with the engine OFF(trying to make sure the parking paw isnt in place) EDIT Is this a trans brake V/B ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 80fbody]
#1420142
04/15/13 11:52 AM
04/15/13 11:52 AM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Are you saying it won't move in 1st at all but will shift to 2nd and 3rd OK? The reason I ask is a LONG story but my next question might give you a clue. ![](/ubbthreads/images/graemlins/laugh2.gif) They didn't send you a reverse pattern by mistake did they? Kevin
[Re: Twostick]
#1420143
04/15/13 12:13 PM
04/15/13 12:13 PM
MR_P_BODY
Kevin
Thats why I asked if it would move in 1st with the engine off(that eliminates any hyd issues) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1420144
04/15/13 01:47 PM
04/15/13 01:47 PM
StealthWedge67
Puyallup, WA
It is a Turbo Action #17675 valve body (Non-brake, forward pattern, LBA). The car is still in the air on jackstands. What I'm describing is from watching the rear wheels in the air. With engine running; 1st: no go / locked up against the converter. Everything else seems correct. With engine OFF, wheels WILL move in 1st (as well as 2nd and D). So in my mind, that eliminates the Park rod issue, correct? And means that it IS something hydraulic, correct?
Also, just to confirm: I did check the shift lever in each gear against the shifter. It IS properly getting into each gear position.
My luck..... Paul is out of the office all day today. Won't be able to get ahold of him until tomorrow.
#1420145
04/15/13 03:09 PM
04/15/13 03:09 PM
MR_P_BODY
It is a Turbo Action #17675 valve body (Non-brake, forward pattern, LBA). The car is still in the air on jackstands. Wi What I'm describing is from watching the rear wheels in the air. With engine running; 1st: no go / locked up against the converter. Everything else seems correct. With engine OFF, wheels WILL move in 1st (as well as 2nd and D). So in my mind, that eliminates the Park rod issue, correct? And means that it IS something hydraulic, correct?
You are correct... the wheels turn with the engine off then its a hyd issue... basically 2 items on at the same time.... yep... call Paul ![](/ubbthreads/images/graemlins/wave.gif)
#1420148
04/15/13 07:21 PM
04/15/13 07:21 PM
Triple Threat
Renton Washington
I have a valve body you can borrow to get the car moving, its reverse pattern but, the price is right.
[Re: Triple Threat]
#1420149
04/15/13 07:45 PM
04/15/13 07:45 PM
StealthWedge67
Puyallup, WA
Thanks for the offer, Dustin. I have my TransGo / stock one as well If I wanted to do that, but I only want to remove the pan on this thing once to fix this, and I do want this particular VB (forward & LBA).
#1420151
04/16/13 02:21 PM
04/16/13 02:21 PM
MR_P_BODY
Well, I talked with Paul Forte at T-A this morning. He concedes that it sounds like a valve body issue. Out it comes.
Well at least you dont have to pull the trans... hopefully ![](/ubbthreads/images/graemlins/wave.gif)
#1420152
04/16/13 08:41 PM
04/16/13 08:41 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
This is all a part of paying your dues. Keep smiling! I have broken more parts than I can count and I am sure that I will break more in the future.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: 727 locked up while in 1st ??? - UPDATE
[Re: Polarapete]
#1420153
05/23/13 01:59 PM
05/23/13 01:59 PM
StealthWedge67
Puyallup, WA
Uggghhh...... Its nearly June!
Just got off the phone with Turbo Action. Paul says he didn't find anything wrong with the valve body, but hasn't tested it in a transmission yet. He DID offer to just send out a new one, which I jumped on immediately. but then he quickly noted that they didn't have any 17675's in stock, and he would have to build one. Said he could get it out next week.
Thank god my daughter has kept me busy with her Fastpitch Softball schedule, otherwise this would REALLY be pissing me off.
#1420154
06/13/13 04:55 PM
06/13/13 04:55 PM
StealthWedge67
Puyallup, WA
*********UPDATE: June 13th******** After a few phone conversations with Paul Forte @ TurboAction over the past few weeks, he is finally sending out a new valve-body today. He decided a few weeks ago, before sending a new one out that he needed to completely verify mine was defective, so after not finding an issue with it on the bench, he installed it into their mule car and.... bingo. it did the same thing it did in my car (1st gear locked). Since he couldn't find anything wrong with it on the bench, we decided that it would be best to check the new one he was going to send out in the same car, which he did and found no issue. bottom line, the valve body I had somehow has a "ghost problem" that Paul cant figure out. He verified that a new one worked fine and it's in the mail. Why am I bothering to post this non-sense??? ![](/ubbthreads/images/graemlins/2516024-blahblah.gif) I don't know. maybe because its the closest thing I've had to actually driving my car in a number of months now. Jeez this is frustrating. ![](/ubbthreads/images/graemlins/2241092-prplchrgr.gif)
#1420156
06/14/13 10:33 AM
06/14/13 10:33 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
""Why am I bothering to post this non-sense???""
Paul is a great guy to work with.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
