Disc brake conversion???
#1420048
04/14/13 08:46 PM
04/14/13 08:46 PM
abc440
I put front brake conversion kit mannual( new rotors, calibers, hoses,MC, spindle, pads) about 3 weeks ago. Had heating up rotors problem and front wheels being real tight to spin when getting back from 3 mile trips. Changed out MC (mannual), no heating up problems or tight wheels, but still a hard pedal and not much braking. Bled lines with hand vaccum pump 2 times, and once with helper pumping up pedal 3 or 4 pumps and holding, me releasing bleed screw with just a dribble fluid coming out of each screw,(just a couple a drops). What is wrong?And also do I need a power brake booster/MC? This is a 71 B-body with a mannual drum brakes oringally. How much trouble to put power on and where to buy booster.MC? Thanks
Re: Disc brake conversion???
[Re: abc440]
#1420051
04/14/13 10:34 PM
04/14/13 10:34 PM
Posts: 532 Marion, Ohio USA
kab69440
Marion, Ohio USA
Sounds like your hoses have collapsed. Are they new or recycled from another project?
Just because you're paranoid, it doesn't mean they are not out to get you.
WANT TO BUY- Looking for a CD by 'The Sub-Mersians' entitled "Raw Love Songs From my Garage To Your Bedroom". Also, any of the various surf-revival compilation albums this band has contributed to.
[Re: abc440]
#1420054
04/14/13 11:25 PM
04/14/13 11:25 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Not sure on B-body but in a "C" you need to change the pedal assembly.
I have mechanical Aptitude. I can screw up anything.
[Re: abc440]
#1420055
04/14/13 11:48 PM
04/14/13 11:48 PM
RapidRobert
After you find/fix the blockage you might be Ok with the manual brakes
[Re: abc440]
#1420059
04/15/13 08:46 PM
04/15/13 08:46 PM
RapidRobert
Progress I wonder what the blockage was. The symptoms sure didnt sound like air but sometimes they are tricky.
