Big block torque shaft alignment
#1419915
04/14/13 05:01 PM
04/14/13 05:01 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
I've got another thread thats been going for about a year now, so i figured i'd start new topic for this specific question. I'm working on a 440 4 speed swap into my 73 challenger using a lakewood scattershield. I've got a mock up block and the transmission all bolted in so i could weld in the tunnel hump and the torque shaft frame bracket. After fiddeling around with many different options. This one is the only one that gets close to working. I have 2 torque shafts, one of them i cut the bracket on the clutch adjuster side off, and moved it over a half inch (per the specs brewers gives on their websight) So far i've just spot welded the frame bracket into place. Anyway, does anyone have any pictures of their torque shaft? Maybee some pics with the facotory torque shaft set up, and hopefully someone with a scattershield. I'l lie to know if this is going to work so i can pull the mock up out and finish welding the frame bracket in. Any advice would be great as this is my first 4 speed swap. Here's my set up so far.
Re: Big block torque shaft alignment
[Re: Jim_Lusk]
#1419918
04/14/13 09:40 PM
04/14/13 09:40 PM
Posts: 2,364 PA
70HemiGTX
PA
Toss the little bracket off the bellhousing and put the ball-pivot directly in the hole that makes the shaft most level. Looks like the lower hole.
[Re: Stanton]
#1419920
04/16/13 06:11 PM
04/16/13 06:11 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
Already had it screwed into the lower hole. The torque shaft is still tilted when put in that position (the other way), and the clutch adjuster plate on the torque shaft then hits the starter nose housing. I could cut it off and reweld it again EVEN FARTHER in, but then the actual clutch adjuster shaft would be at an overly severe angle, and since the shaft would now be tilted the other way, i don't think the regular clutch adjuster shafts would be long enough to reach the cluth pivot arm.
I could keep the bracket, and not use the notch in the frame frail for alignment. This would require moving the bracket towards the back of the car more, and cutting away some of the fender well in order to get a nut on the back of the ballstud. I feel like there's probably an easier solution that i'm missing.
If i moved the welded ball stud on the bracket a little futher back it would put the shaft in aligment, but would interfere with the mounting hole of the bracket.
Anybody else have experience with this? or at least some pictures of a factory big block setup? Hopefully with an 11" bellhousing.
[Re: Stanton]
#1419930
04/18/13 11:48 AM
04/18/13 11:48 AM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
Also are you sure your arm has been moved? Mine were originally 3/4" from the end, but they REALLY hit then. one of mine is still 3/4" from end, and the other is modified to be 1.25" from the end.
Did they make a longer pedal to torque shaft rod that would index the torque shaft more, keeping it away from the bellhousing flange?
[Re: Stanton]
#1419932
04/18/13 03:23 PM
04/18/13 03:23 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
This is from Brewers website.
Torque Shaft, fits big block 1966-70 B-body, small block 1970-74 E-body & 1971-74 B-body applications. Also works in 1970 & later B/E-body cars when using earlier 11" cast iron or Lakewood bellhousings. 9" tube lenght, lower offset adjuster arm welded 1 1/4" from end of tube, uses our AK449 adjusting rod kit. Reference OE part numbers 2534 538 and 2950 914
So comparing this to mine which is 8-1/4" long, it has been shortened 3/4" on the bellhousing end and the arm moved what looks to be about the same amount. What's interesting is that Brewers says this will work with the scattershield yet mine has clearly been modified in order to work.
If you're wondering why I'm not too sure about what was done, its because I did all this 39 years ago !!
[Re: Stanton]
#1419933
04/29/13 10:53 AM
04/29/13 10:53 AM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
Ya I'm curious about brewers wording as well, because i made mine to the specs the say should fit, and it doesn't
I've been gone the past week on vacation, but i'll update the thread when i get some time to work on it.
