Stock Oil Pump Shaft with Milodon 21814 Pump? #1419831
04/14/13 01:41 PM
04/14/13 01:41 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I am using the Milodon 21814 oil pump, do I need a special length oil shaft or does the stock length oil shaft work? Thanks.
RS23L7 4-Speed
Re: Stock Oil Pump Shaft with Milodon 21814 Pump? [Re: Mopar_Mike] #1419832
04/15/13 12:44 AM
04/15/13 12:44 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
theirs 2 different shafts for there pumps you can measure it up on mock up or just buy from them as per the pump #.I bit the bullet after finding out my bronze gear shaft was to short!
Re: Stock Oil Pump Shaft with Milodon 21814 Pump? [Re: Mopar_Mike] #1419833
04/15/13 01:10 AM
04/15/13 01:10 AM
new york usa
P
pattyboy 572 Offline
P
new york usa
this pumps use stock length shaft.....per summit site....http://www.summitracing.com/parts/mil-21814
Re: Stock Oil Pump Shaft with Milodon 21814 Pump? [Re: pattyboy 572] #1419834
04/15/13 07:38 AM
04/15/13 07:38 AM
Danville, NH
Danville, NH
awesome, thanks for the info!
RS23L7 4-Speed
Re: Stock Oil Pump Shaft with Milodon 21814 Pump? [Re: Mopar_Mike] #1419835
04/15/13 10:44 AM
04/15/13 10:44 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
There are 3 length gears
8.50
8.187
7.875
The 8.50 is for any system using the Milodon plate
the 8.187 is for the Milodon pump
the 7.875 is for any stock or HV (melling, sealed power) pump.
Todd
